Question about GE WPGT9350C Top Load Washer
Problem Warning or Notice
Screen display the following: Notice: A problem has been detected with this unit. The machine does not do anything. I have unplugged and waited for 30 secs. After re-power, the machine "thinks" and not matter what cycle I select the same notice appears after the initial start. The cycles I have selected were: washing, rinse and sping. What is the solution to my problem?
  • Anonymous Mar 12, 2014
    I put my machine on this morning and the instructions came on in Spannish. I have tried to follow the instructions for changing the language but unfoertunately it said to wait for a beep and this didn't happen. I could see that the temp and spin was what I usually have it on and took a chance that it would still do my wash. However, I have noticed that where it says wash in Spanish there is also anothefr word which I cant translate but I now think that it could denote length of the cycle which is over 2 hours
    President:
  • 878 Answers
Pleasant, Under the console you should find the tech sheet showing the error codes and steps to solve this issue. First try this: Press and hold the my cycle and back button together for 3 seconds. The field service screen should appear with any error codes. Make note of them. Then touch the exit button. This will clear any errors. Then unplug the unit for 1 minute. See if your washer comes back to normal. If not you will have to get into the exact error codes and track it down from there. They will be on the tech sheet. Hope this helps solving this issue.
Posted on Jun 11, 2006
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
Stuck on "problem detected" screen
Hi deejay961...You may want to begin with the following procedures. Please update your post with your results, and if needed, we can progress until we correct your issue....good luck my friend...chris The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature. "A problem has been detected with this unit" will be displayed on the screen. The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control. Solution: 1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT. 2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in. 3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 23, 2007 | GE WPGT9360EPL Top Load Washer
Replaced broken motor coupler and motor still saying problem has been detected with drive system
Solution:
Dec 01, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Wont run
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is mnunocortes@hotmail.com Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Notice a problem has detected with this unit
If the home screen is not displayed press home then help. Then press my cycles and back together for 3 seconds.  Read what its says and then turn the power off then back on. It should be ready to go!
Nov 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Stuckon screen
Solution:
Oct 20, 2007 | GE WPGT9360EPL Top Load Washer
Notice! A problem has been detected with this unit
Troy, see if you can get it into a factory test mode. Start by pushing the power button on; next push the home button, next push the help pad, next push the start/stop and help pad together for 3 seconds, push the test load, the contrast screen should display. Now you can cycle through the different tests or let it cycle through on it's own, each test should time out after 5 minutes. This test will include the main board operation. If any tests fail, a failure code will appear. To exit the test, press stop/start to scroll down the screen list until the screen darkens. In case this model number is not exactly correct you should be able to find a tech sheet under the consol to guide you through these test proceedures. We need an error code to find the real problem, almost sounds like a pressure switch problem. Catriver..post back.
Aug 25, 2006 | GE WPGT9350C Top Load Washer
GE WPGT9350C Top Load Washer Logo
232 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
