Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
JVC AV-48WP30: CONVERGENCE PROBLEM!!! HELP!!!
I woke up this morning with my Tv has shadowing pictures and the top left screen has waving red shadows. I checked the convergence and the green + and blue + are apart with each other, i tried moving it manually and all the right +(3,6,9) where properly aligned, +4 was aligned too but all the remaining esp the middle + (2,5,8) i cant move them using my remote arrow keys...
can anybody help me solve my problem?..how to do the what they call AUTO convergence? help me the proper way to fix the problem.
THANK YOU.
    Top Expert:
  • JVC Master
  • 12,962 Answers
U have convergence board issues. Sometimes over time the solder joints on the board go bad or develop minute breaks. U might try removing the board and resoldering every thing you can get it. U can also consider baking the board in an oven at around 270 degrees for about 8 minutes to melt all of the connections on the bottom of board.
Then remove, allow to cool, cross your fingers and see what happens.
Posted on May 05, 2017
  • 1694 Answers
SOURCE: Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Posted on Sep 29, 2007
ctf1800
  • 4402 Answers
SOURCE: shadow around objects in picture...shadow is bluish
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
ctf1800
  • 4402 Answers
SOURCE: PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
no this is what you need...
Convergence amp ic bad
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Posted on Feb 07, 2008
mfspencer
  • 58 Answers
SOURCE: jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Posted on Apr 02, 2008
My JVC wont converge the red lines so half my screen is good while the other has red lines. What should I do? Thanks A lot
The tv 100% have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors picture shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc48av-wp30 problem with red lines up and down on tv
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Red shadows in 48" JVC rear projection
Well you better be pretty handy with a soldering iron. The convergence output IC's need to be replaced. These are large plastic pack IC's with 18 or so pins that are soldered on the underside of the circuit board. These IC's are mounted to large metal heat sinks.
Jun 17, 2009 | JVC AV-48WP30 48" Rear Projection...
Red and green shadows
Your tv has a convergence board problem. Have a technician replace the convergence IC's.
Jul 08, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP34
The convergence ICs need to be replaced. I can post a link where to get replacement ICs along with free step by step instructions so you can do the repair yourself. Its an easy ,common repair , however a shop will be around 300 to 400
Mar 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Blue shadow across my screen
Go into the convergence function from the menu and see if it works. If it does not then the convergence board has a problem. JVC still sells the part.
Jan 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Red and Blue shadowing (Where are my 3d glasses)
There are two convergence IC's that are bad and need to be replaced, as this happens to almost every rear projectionj set ever made. They are stand up IC's , on a heatsink and they start with STK. They are soldered into place and this set has no user replaceable parts inside of it. If you have no solid state repair experience, you really should call out a trained tech to assist you in this repair. A TV set is no place to be diggin and experimenting inside of.
Sep 24, 2006 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP30 red "shadow"
The problem called Convergence problem. Unfortunately, some sets have manual convergence boards - which means you can do nothing but replace it and adjust the manual controls on the board itself. But some of the newer ones (Maybe yours) can be accessed through a service mode. So, give it a try and look for a service mode in your set... Good luck!
Jan 02, 2006 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
