Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Trinitron 36" led flashes 11 steady flashes then 5 quick.
When I turn it on nothing happens to screen or sound. Led flashes 11 steady flashes then repeats 5 quick ones after that. It just started today
  • 790 Answers
Hi
You have defective power oscillation in power circuit! this need to diagnose to find the bad parts!
Thanks!
Posted on Oct 21, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV-36xbr800 led flashes 5 times ??????
A common cause is the HV multiplier module is failing. Sometimes a failing CRT can cause this type of fault. There are other support components that can be going out of spec with age.
Considering the age of the set, I would be looking for a newer set. If you invest money in to this set, there is no guarantee that in a number of months from now there may be other faults.
Jerry G.
Jan 09, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trinitron 36 will not come on but led flashes 5 times quickly
yeah, this are the circuits that you have to check,horizontal ckt.and the vertical ic it might be bad you need some electronics repair skills in order for you to do this.
good luck
caypianan@yahoo.com
Oct 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-36FV27
Replace all 3 video ic outputs on CRT broad #TDA6111Q,
Feb 06, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
Sound but no picture
The only time I have seen a Sony set with absolutely no picture and no on-screen menu but no error codes from the front LED, the main signal CXA jungle IC was bad and needed to be replaced. This is something that should only be attempted by a qualified tech familiar with Sont sets.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
