Lexmark printer to be connected to my windows vista computer
My lexmark printer is just the one that print blackand white . just a ordinary printer
    Master:
  • 763 Answers
Sir can you pls specify the exact model of your lexmark printer. did you try to uninstall and reinstall again your printer from your computer and did you try to print with other software or programs see if the same happen?
CHARCOIS
Posted on Oct 18, 2008
  • 1,879 Answers
What is the exact model ? well look it up for you.
    Genius:
  • 1,550 Answers
Some model of Lexmark is not supported by vista .
Can you post the model number ?
    President:
  • 1,952 Answers
Have u checked ur cartridge?
  • mohammed marika thambi
    mohammed marika thambi Oct 18, 2008
    Downloads GX4PEK Printer Tester is a small utility for testing any printer you like. Just select one section (from Black & White printing, Color & Advanced B&W printing or Advanced printing), then select what test you want and press START printing.
    Print Text Only to remove images
    Please check color cartridge is ok or not
    if it is ok then check your printer configuration in Your pc it should be a gray scale printing ..
  • 19,396 Answers
Many old printers do not work on Vista, click the link below, put your model in the list and select vista in the box that says "select os", if you do not find driver download then prionter does not work on Vista:
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,find thefile,double click on the file, then if you get introubles,follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
I have a Lexmark x7350 connected to a PC running Win7. I have previously been able to print with this combo with no problems at all. I have removed the device, uninstalled the Lexmark software, rebooted,...
Please follow the steps on to properly Uninstall Lexmark Printers from your computer. After the uninstallation process is done, reboot pc when prompted.
When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the link below to download and install the Lexmark X7350 Printer Driver on your computer. Note: Use the Vista Driver on Windows 7. - Lexmark X7350 Driver for Vista 32-bit - Lexmark X7350 Driver for Vista 64-bit
When the installation process is successful, try to print a document to verify that the problem is fixed.
Sep 11, 2011 | Lexmark X7350 All-In-One InkJet Printer
Printer won't print
Although Lexmark has not released a Windows Vista driver for the Lexmark X75 printer, there is a good chance that Vista will support your printer without the need for installing a driver (i.e. Windows Vista probably comes with a driver for your printer already built into the operating system). Windows Vista comes with support for 2.2 million devices and since your printer is not a new model, it is likely to be supported. Just try connecting it to a computer that is running Windows Vista and see if it is detected and installed for you.
We do have the drivers for Windows 2000 and Windows XP available for download from our driver database:
Lexmark X75 Printer Driver
Jan 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Networking printer issue
vista open devices & printers add printer connect direct via cat5 patch power cycle lexmark
Nov 16, 2008 | Lexmark (13A0288) Network Adapter
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
LEXMARK 1200 SERIES
This problem occurs because your printer doesn't support Vista.
Nov 15, 2008 | Lexmark X1270 All-In-One InkJet Printer
Just got new computer with windows vista now my lexmark p6250 printer dos"t work
  1. Go to the Lexmark Find Drivers/Product Selector page.
  2. Enter Lexmark P6250 under "Search by Model", and click the Search button.
  3. Select your OS from the dropdown (Vista).
  4. Click Download Now.
  5. If you're asked to Save or Run, choose to Run (it keeps you from having to go find the file and double-click it later).
Jun 27, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Cannot print on my lexmark 1150 using Windows Vista.
lol. i have a Lexmark x125 and it wont 'communicate' with the computer !!
May 04, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark x 1185 on windows vista
hi you can get the drivers from lexmark site here Windows Vista --
if you need em for download
riz.
Apr 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
53 people viewed this question
jasbo
jasbo
