Question about Toshiba SD M1712 Internal DVD Drive
Dvd drive icon missing
Hi
I am using Toshiba A135 laptop from 1 year recently i found my dvd drive icon missing i removed lower and upper filter and restarted but still i am facing the same problem.
U r co operation to me in this regard would be highly appreciatable
Thanking you
  • 916 Answers
Check the same place you did for upper and lower filters and also remove the upper and lower .bak entries. Then restart the machine. If the problem is still there check the drive connections and check to make sure the drive is still good.
Posted on Sep 07, 2009
Cd-R/W driver works no more for Toshiba a135
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Apr 19, 2012 | Toshiba Satellite Satellite 5200 Series 15...
My dvd is not detected and is missing from drive list, dose not work
Dvd Drive sound like it is no longer working and needs to be replaced.
Jul 11, 2011 | Computers & Internet
My Lenovo 3000 G410 Optiarc DVD RW AD-7560A ATA doesn't read dvd or cd anymore... so I can't install Ubuntu for my laptop. can you tell me what is the problem???
Did this just happen recently? Have you recently installed a new software in your computer? because sometimes when you installed a new software that is not compatible with the software installed in your computer conflict may arise and malfunction may follow but no worries there are a lot of trouble shooting steps you can do to fix this issue, you can either do system restore or delete the upper and lower filter in your computer.
To delete upper and lower filter follow the steps below:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
I hope this information will be helpful. Thank you for using FixYa!
Your Feedback is greatly appreciated.
Feb 25, 2011 | Sony Optiarc AD-7170S Burner
CD/DVD drive not recognized - it doesn't show up in the device manager at all. I am ready to throw it off a cliff.
Hi, Please Follow theses insructions:
Go into BIOS upon powering the system keep on tapping f1/f2 to get to the BIOS screen go to boot check if the dvd/cd-rom is detected there if it is detected there then do the below step by step.
Click Start, All Programs, Accessories, Look for Run or Command Prompt, a windows for regedit will come up on the screen select the specified below
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once you see the DVD/CD-ROM Drives Delete upper and lower filters if you show both on the list uner name, then restart your computer.
I Hope this will be a big help to your concern ^_^ THanks.
Jun 12, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite L40 dvd player will not work. have re-installed dvd player and tried updating driver but nothing is happening
Open your Windows Explorer (My Computer) window. Is the DVD/CD icon there? If it's not there, follow these steps:
  1. Click the following link to download the remove upper/lower filters from the windows registry._ http://tiny.cc/9BV5G (RmvFltrs.exe). Save the file to the Windows Desktop.
    Unzip then,
  2. For Windows XP, double-click the file RmvFltrs.exe on the Windows Desktop to start the installation program.
    For Windows Vista, right-click the RmvFltrs.exe file, and choose the "Run as Administrator" option. If a User Account Control dialog box displays the message, "An unidentified program wants access to your computer", click Allow.
  3. Follow the onscreen prompts to complete the installation.
  4. Restart the Computer.
    It should work.
Nov 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Dvd rw is not detected in windows xp in my toshiba a75 laptop
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > click on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and select uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 07, 2009 | Toshiba A75-S125 Satellite Notebook
Matshita dvd-ram uj-831s driver missing
please go in bios check the drive is shown there.
if shown and not showing in my computer then might be the os issue.
Go to the device manager and check any yellow question mark on the dvd/cd rom drive and if not then try following
Right click and uninstall the drive.
Go to IDE ATAPI controllers in device manager and uninstall secondary controllers or ata channel 1 from there.
Go to run option>type regedit and enter then>H_KEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>first entry starting with the 4D36 and single click on entry>on the right hand pane check for any lower or upper filter and if there delete both.
Restart the system twice then check if then also not working might be OS or drive faulty
Thanks.
Feb 22, 2009 | Toshiba Satellite A205-S4617 Notebook
Laptop
I recently lost my CD/DVD drive when I (correctly) uninstalled a Roxio application from my Toshiba laptop. After a week of frustration, I finally found the fix. My CD/DVD drive is back!
Go to the Windows START menu.
Click on RUN and enter: regedit
FOLLOW THIS TREE:
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
In the CLASS folder, look for:
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters] You will see the upper and lower filters folders once you get to the end of the tree… *\*\*\control\class
If a backup folder for either the upper or lower filter folders shows up, clear all the data from these folders as well.
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
Nov 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
GMA 4082n device driver not working properly code 39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Dec 02, 2007 | Toshiba Satellite A135 Notebook
Toshiba SD M1712 Internal DVD Drive Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
