Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Lense Protection won't open
The unit turns on but the lens covers won't open. One side can be moved but the other doesn't move.
DMT
  • 489 Answers
Hi
There may be dirt or something else that has caused the cover stick, or the spring may have popped off if you dropped the camera... Hard to say without taking off the front cap and looking at it.
Turn the camera on and extend the lens, then open the battery door to shut the camera off but keep the lens extended. If you use a small screwdriver you can pop off the front cap, theres a small notch in the bottom of the ring, press it up there.
When you take the cap off the parts underneath may pop off and go flying... be careful. If you have all the parts, look for damage or dirt. Clean if dirty and put it back together.
If you lose a part or need a new kit I know one and only one spot where you can buy it... and it just happens to be me. We are a digital camera repair business and can supply you with the parts or do the repair for you.
If you search the site (Darntoothysam com) for your model number you will see the listing for the parts and one for the repair service where you send us the camera and we install them for you and ship it back.
Hopefully this will help, good luck from Darntoothysam com
Thomas
Posted on Oct 18, 2008
My lens won't open all the way, but no error is listed.
its normally only the Lens Protection Cover - mostly a bit of dust in between or slightly bend (cam wont recognize that) try to blow out or take a toothpick and slightly try to move the lens covers . sometimes enough to fix it !
Mar 21, 2015 | Nikon COOLPIX S9500 Digital Camera Black
Shutter wont open or close
Hi seems to be a mechanical problem.
Feb 20, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Lens froze position
I've just got the same problem, don't know what to do!
May 04, 2013 | Nikon COOLPIX L810
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
I have the aperture at the lowest number but when I look into the viewfinder everything is dark and when I turn the aperture to lighten up the viewfinder it gives the fee
It sounds like the mechanical lever in your camera that normally couples the aperture to the camera to lock it to the widest opening for focusing is locked into the fully closed position, or that the electronics are not allowing the lens to open to fully open, depending on the type of lense being used.
Also, it could be an issue with the lense.
The simple way to test this will be to remove the lense, and to rotate the aperture ring while looking through the lense. If you see the aperture getting larger/smaller the lense aperture is fine. If it is not - the lense is damaged and needs to be replaced, or at best serviced. This can be done through Nikon, a local shop if you have one, or through online shops, I'd recommend KEH Camera in Atlanta if you have to go that way.
To test the camera side, if the lense appears to be working is also simple for the mechanical lever. With the lense removed, hold the camera in front of you looking into the lense mount. On the left side, you should see a small lever like piece. With your finger, see if this piece will move downward - it is spring loaded and should smoothly go down and pop back up. If it doesn't go down, or doesn't spring right back up, then the issue is on the camera mechanical side.
If both of those check fine, you may try a manual focus Nikon mount lense if you have access to one - to eliminate the camera electronics from being an issue, and the lense from being an issue as if this lense doesn't work, it's a mechanical issue. If you have access to another AF lense you know is working, and it doesn't work on your camera, you've narrowed it down to either the mechanical lever, or the electronics.
Most likely culprit is the lense itself.
Aug 26, 2011 | Nikon N65 35mm SLR Camera
MX1063 will turn on and lens comes out, but immediately turns off and lens goes back in. I charged it for hours and still nothing.
The outside of the lense may be dirty. When it comes out clean it. Or something else prevents it from fully opening. If it is clean, you might have droped it and damaged or broke mechanical part(s) of your lense. When it opens, try to hold the lense open, do not force it. If the did not help, take out the lense from the camera and inspect the lense. look for broken, or bent parts. Clean it and push the lense in and out. If it moves in and out without any problem, put it back on your camera. If the problem was from the lense, your camera should be back to normal.
Good luck!!!!!!!
Jun 10, 2009 | Kodak EASYSHARE M1063 Digital Camera
Disc does not spin
        This problem shows that the lense of your Play Station reached at its end. You have to change the with new one.So, replace the optical lens and enjoy the games again.
        Thanks and happy gaming :)
     Bye
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Unable to load playstation dics or any other discs for that matter
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Mar 05, 2007 | Olympus Camedia Stylus 300 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
