Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore 21875 One day it's working fine. Next day, it won't turn on. When I attach the hose to another vacuum cleaner, it runs. Is there a reset button on the canister? Could it be the receptacle is bad? My Kenmore Progressive won't turn on today either -but was fine last week. I cleaned the filters checked for blocked air, tried a different outlet and no luck. I'll check the pins on the connections and see if one of them is not matching up or appears worn.
  • wright129 Dec 27, 2008
    Is there a reset button on the Kenmore Progressive canister?
    Kenmore25512 Progressive Canister Vacuum
    Problem Solver:
  • 6 Answers
Give the prongs a wiggle and see if there is any play in them.Might just be a plug end.
Posted on Oct 26, 2008
Where is the CVA located in the Electrolux Epic 6500SR?
You need to replace the control valve. It's inside the canister under the dirt cup. If you want it done by a professional, call your local authorized Aeurus dealer.
Jun 28, 2015 | Electrolux Vacuums
When I replaced the bag, the bag replace light comes on unless I don't use any attachments. what is the problem?
Could be a blockage, push a broom handle through the pipe that will clear it.
Oct 18, 2014 | Kenmore Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Vacuum shrinks, power is still on but no suction
perhaps there is something stuck in the vacuum. Look where the hose fits in. There is obvioulsy no blockage in the hose because you have suction. Do the power brushes spin on the vacuum?? Take the bag off, and inspect the area the bag fits in for blockage.
Jer
Jan 16, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
May 13, 2009 | Vacuums
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Kenmore progressive/direct drive-- roller stopped turning
We have the same vacuum & had the same problem. As the vacuum ages & the hose is periodically removed from the nozzle to use with the attachments, the white switch, adjacent to the nozzle connection, wears. If the hose is not fully reinserted or if the attachment notches are inadvertently aligned with the white stitch, the agitator may not work reliably. Assuring the hose is fully inserted, with the locking notches away from the switch has eliminated this problem with our vacuum cleaner.
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore 21875
My first recomendation would be to try pluging into a diffrent wall outlet as well as something that is on a diffrent circut . It is a known problem that the pins inside that make the connection could be worn out . There are several pins from the one on the hose to the handle ect , check all componants to see that where the connection is lost you will find that you will need to replace that componant
Sep 17, 2008 | Kenmore 21513 Vacuum
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
205 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
