Question about Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1002W
The machine will not fill with water when programme started,same problem all programmes.There are no blockages and the water flow to the machine is fine. What could the solution be? is it possible a programme problem? if it is, is there a code sequence that can be entered?
My washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Posted on Jun 25, 2010
  • 99 Answers
Water selonoid.Or filter in hose blocked,
Posted on Oct 18, 2008
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Tumble dyer is spinning but not heating up
I dont know your Dryer model or if it is vented or a condenser dryer.It could be the main heater has gone or the programmer.There is also a safety thermostat which could have blown.It is worth checking for blockages in the filters and condenser stack etc. and the water tank.If vented check outlet pipe is not crushed or blocked.
Hope this helps.
Jul 12, 2010 | Tricity Bendix Dryers
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
Solve Your
I have spent most of the afternoon looking for the float etc. In frustration I upended the machine to look for the inlet hose point, water started pouring out so I put the machine back in the upright position. Now it's filling with water and working again. Maybe there was something in the hose which became free with upending it. Not sure, but worth a try, it worked for me!
Mar 11, 2010 | Tricity Bendix 18 in. DH090 Free-standing...
Can't get main pulley parted from back of drum. flat brass screw with a torque centre won't screw either direction to access main shaft to replace bearings. machine is tricity bendix aw1100s
Try some heat to the screw with a propane torch , or a hot air dryer, and try spraying some WD40 on the screw. it should be a normal right hand thread.
Please rate my solution.
Thanks.
Nov 24, 2009 | Tricity Bendix Washing Machines
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
792 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
