Studio Series 54
I need to get the remote that came with my DirecTV to work my tv. I can't find the code I need. I'm having to use 2 remotes now. The DirecTV remote will not turn tv on and off, won't mute, can't change volume, etc. What is the code I need so that I can use the DirecTV remote only.
Thanks,
rapple
  • rapple Oct 20, 2008
    I have looked at that website, & thanks for your help. However, my problem is that I can't find out what BRAND tv I have. I've tried codes for Orion, Samsung, etc. because I've heard they might be the brands, but no luck with finding the code.
  • Anonymous Jan 17, 2009
    I can't get the TV on or off and volume and mute do not work after I cleared the defaults of AV1, AV2 and TV using the standard proceedure. I tried the TV codes ( for Panasonic) and they didn't solve the problem. I also put in fresh batterys but that didn't work either.
    Problem Solver:
  • 5 Answers
Http://www.directv.com/learn/pdf/Remote_Controls/universal_remote_user_guide_new.pdf
Find the 5 digit codes for your TV
Switch/Slide your remote control mode to TV mode.
Press Mute and Select button together and hold it until TV mode flashes twice.
Using the number keys, enter 5 digit code for your tv brand.
Press Off button. Try every single code until your tv turns off.
Some common brands and their codes:
If your TV is
- Sony, code is 10000
- Toshiba, code is 12006 (most models and make sure your remote control is version RC64)
- panasonic 10250 most models
- Samsung 10702 most models
- sharp 10093 most models
Posted on Oct 19, 2008
  • TamirN
    TamirN Oct 21, 2008
    If you can't see any name in front of your TV, there should be some label in the back where you might find the brand.
    good day
How to control volume of bose cinemate with directv remote
The code for the Direct TV remote is 31933. It doesn't work with the new RC71 remote (Direct TV limitation with that remote), but it does with the remotes that have AV1 and AV2 options.
Mar 15, 2012 | Bose CineMate GS Series II Speaker System
Problems programming DVR remote to TV
If your DirecTV remote is in SAT mode and the power button isn't turning the receiver on and off, you will likely need a new remote. There isn't suppose to be any trick to getting the power button on a remote to work. However, only DirecTV tech support can confirm this. I would give them a call right away.
Jul 12, 2009 | Philips Televison & Video
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Nov 22, 2008 | Vizio L37 Television
Manufacturer/brand of Studio Series M5400 tv
Other studio series owners suggest they are based on Samsung T.V;s not sure about the M5400.
A useful contact is the supplier of Studio series TV's in Knoxville Tel : 1-865-694-2704 contact Kelly Green Ext 116 for info
Oct 23, 2008 | Televison & Video
Can't find the remote control codes
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series. ALSO try code 10835.
Sep 06, 2008 | Televison & Video
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
291 people viewed this question
Top Televison & Video Experts
Electro Med Services...
