Question about Panasonic PT-61LCZ70 Television
TV Won't Turn On
My Panasonic PT 61LCZ70 will not turn on and the lamp light is red. This television is less than a year old. What can I do to fix it?
  • 3 more comments
  • Anonymous Nov 02, 2008
    My PT-61LCZ70 will not turn on also but my light flashes green
  • Anonymous Dec 27, 2008
    tv fan comes on light flashes green for about five minutes and then tv goes off
  • tishaj27 Jan 05, 2009
    Green light flashes but the tv never comes on and mine is less then a year old as well. Anyone have a resolution to this?
  • Anonymous Jan 12, 2009
    Same as above
  • Anonymous Apr 03, 2009
    Set is 1 year old. Would not turn on all day. The routine wasthe green light would flash for 4-5 minutes then the red light would flash for 3 minutes before the set would power off. All of a sudden it came on like normal during one of the power up cycles.
    Seems to be a pattern here....
    Problem Solver:
The lamp is bad. panasonic has a 5 year part warranty on the lamp and 2 years labor
Posted on Jun 12, 2009
Replace lamp pt 61lcz70
make this steps and fix it. God bless you
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Jul 31, 2013 | Panasonic PT-61LCZ70 Television
Green light flashes several times. Then TV turn off.
look for 1 of 2 lights in front of the tv. after the tv shuts down completley mine would turn back on for another 30-45 min after a good cleaning it will stay off and give a "power light" not Lamp light 2 flashes. I'm waiting on some help myself. But if it's the lamp light you'll need to replace the lamp....approximitly $600 from what i've read so far.
Jan 11, 2011 | Panasonic PT-61LCZ70 Television
I have a Panasonic 60 inch TV, which I just changed the bulb less then two months ago. I called the bulb distributor and they said send back the bulb for tests. My problem is that I am not sure if it is...
i believe that the lamps on this model are warrantied for 5 years and labor for 3 years from panasonic i suggest calling panasonic for advice on where to go further.
Dec 23, 2010 | Panasonic PT-61LCZ70 Television
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
NO PICTURE OR SOUND
Most likely the Li-Fi lamp is bad. If it is and your TV is less than 5 years old the lamp is covered under warranty by Panasonic but must be replaced by a Panasonic dealer. If its less than 2 years the labor is also covered. If its less than 5 years old and it appears the lamp isn't firing I would contact Panasonic to have a technician look it.
Sep 10, 2010 | Panasonic PT-61LCZ70 Television
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
Panasonic PT61LCZ70 two red flashes, TV doesn't turn on
LiFi lamp has died. Get on this quick as Panasonic has increased the warranty on this bulb to 5 years parts and 2 years labor. Call panasonic right away.
Jun 01, 2009 | Panasonic PT-61LCZ70 Television
Panasonic PT-61LCZ70 Television Logo
933 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
