Question about Baumatic 24 in. BFD62 Free-standing Dishwasher
Baumatic mini4 dishwasher
When switiched on and the program starts the fill operates and does not stop unless you switch the program of or press pause. Anyone
  • 641 Answers
It sound like a water switch level problem. I am not familiar with your specific dishwasher, but there are 2 types of level switches. 1)A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. 2)Floating switch that located inside the dishwasher's bottom and operate a switch. In case there is a floating switch in your dishwasher - check for its smooth movment and check as well the switch by a multi-meter (an on/off switch). Defective switch should be replaced. If level switch in your dishwasher, is a diaphragm device - Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Posted on Jun 11, 2006
Baumatic b15 drain pump will not stop.
Sounds like a dicky or jammed water level sensor. Get a qualified and licensed technician to check it out. The sensor and labour to replace it should only be around AU$50 or AU$60 dollars (excluding callout or pickup / delivery fees).
Nov 10, 2013 | Baumatic 23 in. BDW5 Built-in Dishwasher
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
I've got a Baumatic Mini4 table top dishwasher: what is err6 and what do I do?
Hi and wlecome to FixYa, I am Kelly.
Your table top dishwasher has an open circuit in the thermostat.
'E6' OPEN CIRCUIT THERMOSTAT.
Technical / Advice Telephone. +44 118 933 6933
SPARES
TEL: 0118 933 6922
FAX: 0118 933 6942
UNITED KINGDOM
T: +44 (0) 118 9336 900
F: +44 (0) 118 9310 035
info@baumatic.co.uk
I do not have the parts list for this unit. You wil have to contact Baumatic to order parts.
To correct the E6 code you will have to have the thermostat replaced or wiring to the thermostat repaired that is causing the open circuit.
Thanks for choosing FixYa,
Kelly
Jan 25, 2011 | Dishwashers
Baumatic starts but wont fill BKD45W model
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Dec 10, 2010 | Baumatic 23 in. BDW8 Built-in Dishwasher
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Baumatic BHD5 works then buttons start flashing and it beeps and stops working
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
Aug 01, 2007 | Baumatic 24 in. BFD60SS Free-standing...
My first question - If your dishwasher is still under warranty why you don't ask manufacturer service to take care for it !! Water supply to the diswasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water freely into the tub. Check if water are coming into the tub when the diswasher is off. If this is the situation- Open the valve (very easy to do it)and clean it from scale or other dirt (take care not to lose any part). Be aware you should disconnect the power cable from the machine before doing it !!!!! In most cases it should solve your problem, but if not - you should replace the valve with a new one. Good luck !!
Jun 10, 2006 | Baumatic 24 in. BFD62 Free-standing...
Baumatic 24 in. BFD62 Free-standing Dishwasher Logo
142 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
