Question about Compaq Computers & Internet
Looking for memory slots - Compaq Computers & Internet
    Genius:
  • 1,124 Answers
You have to take out the side cover of your computer. The memory modules slots usually are located at the right of your cpu (fan) - Depending of your motherboard features you will find 2, 3 or 4 slots.
You can see how install a memory module here:
http://www.crucial.com/support/
If you need more help, please let me know
Thank you for using FIXYA!
Pablo :-)
Posted on Oct 18, 2008
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
http://www.4allmemory.com
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
http://www.4allmemory.com/memory/compaq-hp-presario-sr5110nx/
Jun 03, 2012 | Computers & Internet
Where are the memory slots
On the bottom of the laptop there should be a couple panels with icons. Look for one that looks like a rectangular ghost from Pac-man. That's where the memory slots are.
Feb 23, 2011 | HP 6720s PC Notebook
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I have changed my memory but my pc is only picking up new memory from one slot do I need to get it to look somewhere else for the second memory slot?
Your second slot maybe dead, try switching the modules or load one module at a time and boot each time checking to see if the machine boots with either module in either slot. That way you can tell if it is the slot or the module that is the problem. If it is the slot, then that is a motherboard problem.
Mar 26, 2010 | Computers & Internet
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Psp memory problems
have you tried using your memory stick to other units or computer?
1. if its not working it might be damage.
2. but if its working your memory slot in your psp has the problem then look for a technician that could fix your psp slot for memory stick.
i can see that your memory stick and the psp memory slot is not connecting with each other.. hope it help. for more concerns send as a message
May 21, 2009 | Sony PlayStation Portable (PSP) Slim...
PS2 Memory card problem
there is an eternal problem get a NEW ps2
Aug 30, 2008 | Sony PlayStation 2 (PS2) Console
Momory card slot?
I imagine that is just the plastic plug for the bus port. Are you looking for a laptop memory slot or SD camera memory slot. These machines do not have an SD camera memory slot. You will have to get a USB adapter for it. They sell them at Walmart for approx $15. The laptop memory slots are located under a panel on the bottom of the machine. If there is only one slot there, then the other slot is under the keyboard.
Jun 29, 2008 | Toshiba Satellite M45-S165 Notebook
PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
