Question about Whirlpool LBR4121JQ Top Load Washer
Washer won't spin
Washing machine drum won't spin and agitator doesn't move. power is working -- what should I do to determine cause / problem
MODEL IS WHIRLPOOL LBR5232EQ1!
  • denisewillia Jan 16, 2009
    My machine finished the wash cycle then wouldn't spin out. Not the drum won't move at all. I went to purchase a new belt and this model isn't belt driven. What can be the problem?
    Scholar:
  • 112 Answers
The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
Posted on Oct 18, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
How to move around brandt wm 550
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
The aggitator slips
t's supposed to be that way. If you could pull it up whenever you wanted, what would keep it from flying off during a wash cycle? The agitator is loosened from a bolt underneath the wash basket. Do not try that or you could damage the washer. Only a repairman or someone who has worked on washers should do that. Only if you had an article fall apart in the washer (a rug, feather pillow, etc.) should that area truly need cleaning. Call any GE repair shop. If this is under warranty and you have ( as shown ) the model #...........a repair inspector can fix this washer free. Have all your place of purchase documents with you. The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
May 01, 2011 | GE Washing Machines
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool LBR4121JQ Top Load Washer Logo
204 people viewed this question
Dan Webster
Dan Webster
Sal De
