Question about HP PSC 1610 All-In-One InkJet Printer
Printer Cartridge Carriage Stalls
I have an HP PSC 1610 All In One. On the rt side there is a black piece, (looks like a clutch) that when the carraige bangs to the rt it comes down blocking the carriage from moving to the left. I've turned on, off, removed the back, cleaned moved the rollers everything possible yet still this little arm comes down which prevents the carriage from moving freely. Can you reccommend an easy fix?
    Scholar:
  • 181 Answers
The settings of the gears is misalligned.a technician at your place is advisable as this is a very important part of the printer if any of the arm breaks the printer may face major problems.still stick that arm with a cellow tape on it firmly and then give a print out.if the page prints properly that means it got adjusted automatically.
Posted on Nov 14, 2008
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
Chsnge ink cartridge
Hi there!
Here's what you can do to change the Printer cartridges.
1. Make sure that the printer is turned on. Turn it on if it's not.
2. Open the printer cover, then wait until the carriage is idle.
3. You will see the Tri-color & the Black cartridge. The tri color cartridge is the green one which is on the left and the Black is the one on the right.
4. Press down the Cartridge you want to replace you will notice that it will be released from the cartridge holder. Once it's loose slide the cartridge out.
5. Make sure that the correct Genuine Hp Cartridge is what you have. For your printer HP PSC 1610, HP 94 will be for the black and HP 95 is for the tri color.
6. Open the cartridge package. Remove the protective tape. Make sure that you do not touck the copper colored contact and nozzles.
7. Hold the print cartridge with the sticker facing up and the copper colored contacts facing the printer and slide it into the cartridge.
8. Use your thumb to push the cartridge all the way in. You may need a little force to make sure that the cartridge has been installed securely.
9. Once installed close the cartridge cover. Make a copy to test.
Hope this helps!
Jun 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have a HP PSC 1610 all-in-one printer. Can the colour cartridge be bypassed when it asks for replacement cartridge? I only print in black and white now 99% of the time.
No , we all only wish, this is the bane or all printer users. You cannot print without all in full & being OK. Also must use color sometimes else nozzles can clog up. Must clean, too.
Mar 26, 2010 | HP PSC 1610 All-In-One InkJet Printer
Cartridge carriage is stalled
Please let me know how install the ink cartridges blak and color.
Could I have a copyof manual pls
Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Cartridge is stuck in the wrong carriage...
only thin you can do is unforced the ink cart out
Jan 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Print cartridges
Is it a genuine new HP cartridge and also not an expired date? Also may need a new printhead.
Jul 31, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
94 people viewed this question
Ben Johnson
