Question about Frigidaire ATF6000ES Front Load Washer
Atf6000es1 Frigidaire affinity washer
My washer tub gets stuck. It just locks up. I opened up the washer and removed the belt, but the motor is not the problem. It still sticks. Even when turning it by hand, I have the same problems. I took off the bottom hoses and found nothing inhibiting the tub movement.
It seems like the problem is in the seal and my washer doesn't perform. I will free up the wheel with strenuous pushing. It might turn around two or three times but will lock up. can you help me?
SOURCE: Frigidaire Affinity Front Load
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
Posted on Dec 31, 2007
  • 55 Answers
SOURCE: cold water won't stop filling the tub
The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassamble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
Posted on Jan 25, 2008
namzyanzy
  • 435 Answers
SOURCE: FRigidaire Affinity ATF6000ES1 shows "dr"
It may be one of the below listed problems:
  • Cycle selector is not in the correct position.
    Advance the Cycle Selector knob until the indicator is a little further into the cycle.
  • Overloading caused motor to overheat.
    Allow the motor to cool down for 30 minutes. Reduce the load size. The average washer load will fill the drum 1/3 to 1/2 full. If the problem persists, call for service.
  • Thermal limiter switch activated.
    A thermal limiter switch automatically turns off the motor in the unlikely event of an overheated situation (electric dryers only). A service technician must replace the thermal limiter switch after correcting the problem.
Try these measures and then revert back....
Thanks
Posted on Sep 12, 2008
  • 1294 Answers
SOURCE: Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
Posted on Mar 26, 2009
SOURCE: Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
Posted on Jun 13, 2009
Frigidaire affinity error 58
Good Afternoon Friend, thank you for allowing me to assist you!
An error code E58 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing.
Hope this helps! - Z
Jun 06, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a affinity front loader that will not spin. Is there a mixture of buttons to push to make this happen once it is stuck
If the unit will not spin during a cycle, check to see if you can turn or rotate the tub by hand when not in use. If not, you have a seized motor or transmission. If you can move it, then you possible have a bad belt, or control board.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer wont spin code e57
High current issue - 1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 19, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer error 58
High motor current is recognized in the unit:
Aug 10, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Jun 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
98 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
