Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Does the wide screens need a circuit higher than a regular outlet plug
Techman answered my problem... one other thing do you need a higher circuit plug for widescreens... never had a problem with t.v. just shutting off after watching for 30 minutes...
    President:
  • 3,130 Answers
No you do not need a higher current recepticle and dont let them tell you you do as its only a ploy to delay you in getting a new set.!! Good luck Man that was a fast response!! Ps dont forget to vote!!
Posted on Jun 11, 2006
SOURCE:
I can't find an electrical outlet that the plug will fit into
Probably because it requires a different electrical current. Is your machine made to run on 220 volts? If so, it will not work on regular 110 volts (standard household current). You'll need to have a special line and outlet to power 220. The outlets are different because you really don't want to be plugging a 110v appliance into a 220v outlet, or vice versa.
http://www.usatourist.com/english/traveltips/electric-power-tips.html
Mar 29, 2016 | Welding Tools
What is the difference between a regular power strip and a surge protector?
A power strip is what's used for plugging in multiple appliances to one outlet. A surge protector is different in that it is designed to prevent electrical surges from too many things plugged in, bad weather or lightening. Usually things like air conditioners with heavy motors are plugged into surge protectors.
Jan 31, 2013 | Electronics - Others
Cant get my 03 wideglide to idle at lower rpm,bike dies down when lowering idle screw
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 23, 2012 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Can a 240 volt outlet be ran off this breaker and can a 240 volt electric baseboard heater be wired to it or should i use double pole breaker?
You need 240 breaker:
Notice that your 240V breaker is twice as wide as regular 120V breaker.
Notice that both switches are tied together on 240V breaker, making this a double-pole breaker.
For more information about breakers and 120-240V circuits:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
The compressor fills and when it dipenses air and tries to refill it blows a fuse.
the outlet ur plugged into the amps are to low when compressor tries to restart under load which draws more power than what the circuit breaker is rated and or their are other things plugged in on same circuit drawing power and causing the higher amp draw-- plug into some other circuit preferably with nothing else plugged into the circuit or with a higher amp [20amp]breaker
Jan 22, 2010 | Campbell Hausfeld No.FP2028 Gal Pancake...
Microwave fuse blowing???
You really need to check that circuit for ground and neutral faults before using it again.
Aug 29, 2009 | Panasonic NN-H275 Microwave Oven
Refridgerator trips the gfci outlet but will run on a regular out
Do not run a refrigerator or any other appliance on a GFCI that has a start load greater than the GFCI rating. Your refrigerator has a greater start load.
Jun 05, 2009 | Refrigerators
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Nov 27, 2007 | Zenith B25A24Z 25" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
