Question about Acer TravelMate 2300 Notebook
Acer travelmate 4230-6433 touch pad makes unwanted noise when keys touched
An annoying clicking noise occurs when I press the right or left key on the touch pad.
  • velut_umbra May 11, 2010
    Is it a mechanic noise or a software noise?
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
Frozen synaptic touch pad
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 09, 2012 | Acer Computers & Internet
Touch pad not working
Jun 04, 2012 | Computers & Internet
Touch pad is not responding
depending on the model. right aboce it there could be a little button that looks like the toch bad with a line through it. press that and try again.
on another model there was a touch pad icon in the system tray. click that to disable the touchpad. might need an external mouse to do it.
Feb 25, 2011 | Acer Computers & Internet
How do I do the right click function of a normal mouse on the pad mouse of an acer aspire 4741g laptop which does not have a right click button. I have tried to press and hold the Ctrl key and press the...
On your laptop, directly beneath the touch pad are two oblong buttons. They act as mouse buttons. The left one selects and the right one gives extra options.
Hope that helps.
Feb 03, 2011 | Computers & Internet
My touch pad is not working before was ok but now i have to click to left botton for any things tanks
locate the FN key on the lower left side of the keypad,
next locate the touchpad key usually one of the F keys(F1-F12) press and hold the FN keys and the touchpad key, release them and check the touch pad.
PLEASE LEAVE COMMENTS.
Mar 28, 2010 | Acer Aspire 5610-4648 Notebook
How do I turn the synaptic touch pad off on my acer aspire
This should be an easy fix...after many months of trying to disable touchpads on machines that did not have the one button disable feature either in the control panel or on the touchpad itself I discovered it was one of the function keys.
Press function (FN) and the "F7" key...press again to re-enable. Good luck!
Dec 21, 2009 | Acer Aspire 5100 Notebook
The mouse pad on my Acer Aspire 5315-2713 is no longer working. I've had the notebook aprox. 1.5 years. What can I do?
Make sure the mouse pad is enabled. Check the manual or web site for your model. Generally, the mouse pad (and other functions) can be accessed by pressing the Fn key + a specific F_ key (1-12).
Sometimes this device or others can accidentally be disabled.
Dec 06, 2009 | Acer Aspire 5315 Notebook
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
