Question about Vacuums
How to take apart vacuum to change the belt on a F 10051 01 Fantom vacuum
5 Suggested Answers
SOURCE: change my belt on a
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766591
Generic problem for all Vacuums
Change my belt on a
Posted by sylvester021 on Jul 10, 2008
Change my belt on a Fantom vacuum model number is f1420gf
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt change on the Fantom is to remove the bottom plate by undoing the screws, clips or levers, then cut off the old belt, remove the brushroll on the pulley side and place the new belt on the pulley side and replace the brushroll. Then use a belt puller or screwdriver with a hook on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line. The replace the bottom plate and you should be fine. The recommended belt change on a vacuum with a flat belt is every 4 to 6 months for the best cleaning and always use the genuine belts for the Fantom. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
defrankond
  • 65 Answers
SOURCE: fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Posted on Nov 30, 2008
RJones1125
  • 373 Answers
SOURCE: How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Posted on Feb 18, 2009
Vac Belts
  • 701 Answers
SOURCE: Where can I find a belt for my Fantom Fury vacuum
You can get replacement belts and view the manual here:
Fantom Fury Replacement Belts and Manual
Posted on Nov 28, 2009
Testimonial: "Thank you! Very helpful and speedy response."
SOURCE: replace belt on fantom cyclone vacuum?
On my 10-year-old model, the two screws securing the cover are under the two llight bulbs. Pry off the clear plastic covers, take out the bulbs and screws, and the cover lifts off.
Posted on Jan 07, 2010
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
How does one get the belt off of the FM625H? My
I sat down and studied the brush and mashed the two levers on the
front and it came apart. But I am not having any luck finding
the right size belt. I called the 800 number and got a guy wanting
my life history and I never got a number. Thanks
Oct 05, 2009 | Fantom Vacums FM625H Vacuum
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom cyclone xt
Go Fantom Vac site ,type in model #.A PDF
booklet will describe it.
Aug 20, 2008 | Fantom Vacums XT450K Upright Vacuum
Change my belt on a fantom vacuum model number is f1420gf
Change my belt on a
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Fantom fury vacuum
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom cyclone belt status light
The belt may have stretched to the point that it won't turn the brush roll, you might try a new belt and hope that fixes it. Parts for these older Fathoms are scarce and are obsolete.
Apr 22, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom fury vacuums
Most power heads have some screws from the bottom to take out, the the top comes off, then you can get to the belt.
Feb 07, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
191 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
