Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
T.v. just shuts off
Just got my t.v. today an dI plug it in and works fine after 30 minutes it shuts off and sounds like when your power goes out.... try back in about 10 minutes and then it does it again exactly 30 minutes later... made sure it was not in sleep mode... tried again and was able to watch t.v. for 1 1/2 hours and shut off....
  • SANHUMM Sep 06, 2008
    WE HAVE THE SAME TV. HAVE HAD IT 3 YEARS. ALL READY REPAIRED IT ONCE 300.00 DOLLORS AM NOT REPAIRING IT AGAIN. IT TURNS ON NOW FOR ABOUT 1 MINUTE, THEN SHUTS OFF. THE GREEN LIGHT COMES ON FOR 1 MINUTE AND SHUTS OFF. I DONT KNOW HOW TO SELL IT OR GET RID OF IT. I AM SO UPSET WE PAID 1000 DOLLORS BEAND NEW. IF ITS REALLY MINOR I WILL FIX IT THANKS FOR LISTENING PLEASE REPLY E MAIL SANHUMM@AOL.COM
    President:
  • 3,130 Answers
If myou checked with the sleep mode in the menu and its off then you have a problem. If yo0u just got it today and they want to come and take the set and fix it SAY NO you want a new set . Hope you didnt pay cash for it. It was from a store?? good. It unrealistic that you should buy a new set and not even get a day out of it. i would dispute the credit card stop[ payment on the check do what ever you gotta do to get a new set. most store will jump to replace it as they dont wanna lose there commissions.. Speak directly to the manager and make sure they know it started an hout after you plugged in the set. Good luck
Posted on Jun 11, 2006
Samsung dv331ag works fine for 30 minutes then everything goes black after 1 hour works fine again for only 30 minutes
sorry to have to inform you sounds like a bad motor windings? overheating after 20 minutes then shutting down after cool down about an hour it starts agin. A bad venting problem may have caused it?
May 28, 2014 | Samsung DV331AG Gas Dryers
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Turn on notebook (A200 2 years old). Runs fine for about 10 minutes then screen goes blank. if you plug in an external monitor both screens work. This is not an intermittent problem.
Have you check screen power down could be it is setup to shut down as you say after 10 mins. Access power through control panel, change settings ie to 30 mins
Fingers Crossed>?
Nov 14, 2009 | Computers & Internet
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Can't connect to web configuration
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be 192.168.0.2 Open your web browser and type in the IP address of the router (192.168.0.1 by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Aug 26, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
