Question about Jet 3 Ultra Power Chair
Power chair lights
Turn power on to chair . try to use chair and battery light blinks 4 times . what does this mean ?
  • 1 more comment
  • williamhobbs Nov 12, 2008
    I am going to try checking the main fuse in the front...
  • Billyblueyes Apr 06, 2009
    I have a jet 3 ultra worked perfict and then turned it on and the speed lights scroll across about 4 times then it turns off
  • Anonymous Mar 29, 2014
    Tried charging batteries cant get it to do anything. Chair hasnt been used in a couple of years
    Problem Solver:
  • 16 Answers
The problem was a bad joystick. A local company came out to replace it and it works fine now.
Posted on Mar 07, 2009
Where can i purchase lights to put on an invacare power chair
Posted on Mar 03, 2009
What does it mean on 1122 jazzy when the two red lights blink
JAZZY 1122 - Pride Mobility Products
Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
Jul 31, 2015 | Pride Mobility Jazzy 1122 Electric...
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
My aspire powerchair quit and the first 3 battery lights started blinking, what does this mean?
There are thermal fuse under the chair where the batteries are . This is to protect the motors from overheating and ruining them . The fuses are availible on ebay or any medical supply store that deals with wheel chair . I replaced the ones on my mother - in laws Chair and anyone who has a little mechanical ability can change them . They were $10 Each when I replaced hers last December . It is alot cheaper than the motors . That is why they are made that way . Good Luck !!!!!!!!!
Hope this helps!!!!!!!!!!!!!!!!!!!
Aug 16, 2014 | Health & Beauty
Invacare what does it mean when light on charger continually blinks red when charging, It wont move
The red light is the power light and if the red light is blinking the charger is bad or the wiring is bad on the chair or the batteries are bad. Usually it's the charger.
Aug 12, 2014 | Invacare Supply Group Pronto M61 Standard...
Why is Battery Light blinking on Hoveround
Generally, the blinking battery light means that the drives are not fully engaged. Pull up hard on the two levers to engage the drive motors.
Jun 06, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Jun 06, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
400 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
