Question about Viking VIPR101 Kitchen Hood
Viking VIPR101 will not go up or down
I have a Viking VIPR101 domndraft ventilator that will not go up or down.. everything else works...
    Problem Solver:
  • 5 Answers
See the problem and solution at:
Posted on Jan 31, 2010
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
How do I get the old manual switch out of the Viking VWH3010SS?
To read the manual in your browser, click the respective links:
1. Use and Care Manual
2. Installation Guide
3. Specification
4. Ventilation Guides
In case you wish to download them, open this link (Click Here), scroll down to the bottom of the page, locate these:
And click the "Specs" or "Installation Instructions" or "Use and Care Manual" or Ventilation Guide" to download them. If they automatically open up on your browser, right-click the respective icon names and select "Save as..." from the drop down lists.
You'll need a pdf reader to open the file on your computer, click here to download Adobe Reader.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Dec 09, 2010 | Viking Microwave Ovens
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
I have a four burner Viking gas range. How to clean the top?
Something that will work very well to break the grease bond from the metal is Ammonia. The problem with Ammonia is that is puts off fumes and can become a dangerous gas if it is mixed with other chemicals like bleach! So that being said be very careful using it. I would try dilluting it down from full strength to maybe a 50/50 mix of water and Ammonia in a spray bottle. Then lightly spray just the stubborn areas where the food is built-up and let it soak for about a minute. Then use a soft sponge with a scrubby side to remove the food. Remember to go with the grain on the stainless steel or you will see scratches. After you have cleaned the range you will need to apply a really good stainless steel cleaner and polish to keep the stains from sticking to the metal. Remember when using the Ammonia to use it in a well ventilated area and DO NOT MIX it with anything other than water!
Apr 17, 2010 | Viking VGSC366-6B Gas Kitchen Range
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at For example -->
There's a another thread on this forum:
I'll post the exact solution as soon as I have it figured out completely.
Mar 11, 2010 | Viking VIPR101 Kitchen Hood
My Viking VIPR101 Downdraft Ventilator is not working.
It's fixable, but it is easier for them to just sell you the whole expensive part. See the problem and solution at:
Jun 04, 2009 | Viking VIPR101 Kitchen Hood
Viking downdraft ventilator electrical problem.
You seem to have a slightly different model, but see a solution at:
it is probably the same thing
May 28, 2009 | Viking VIPR101 Kitchen Hood
I just took mine a part due to the same problem. I am an EE, so I have some experience in this matter. The problem was indeed the membrane ON/OFF switch. This switch is basically just stuck on the panel like a sticker. You can literally just pull it off and stick it back on. Underneath it is 3 metal "buttons". When you press it, one of these buttons presses on a flex circuit to complete continuity. This send AC line current down to the lift motor under the gear box cover. The lift motor starts moving. After it starts, a cam hits a relay switch, which completes the circuit thru the relay. This is what keeps the vent moving up after you let go of the On/Off Switch.
At first, I through I could just clean the switch up. I figured crud got down in there. But it did not work. I looked at the switch under a microscope, and the problem is the flex circuit was actually burned thru. This is usually caused by a weak spot in the flex combined with too much current. My best guess is this switch is undersized for this application. The switch will also allow current to flow even when the relay takes over, based on how it is wired. I'm not sure I like this, as if one tends to hold the button is all the way up or down, then that just more current thru the switch for a longer time which means more heat and better change of burning thru. Of course if the switch was better quality or design, it wouldn't matter in he first place.
Anyway, I'm going to take the switch to my lab and try and put a jumper wire across the burned area. This probably will not work or it will just burn in another place in the future. So I'll probably have to get another switch. The problem will be finding a good looking one. All one needs is a Single Pole Momentarily ON switch for the application. From it, run the 2 wires the control board connector (polarity does not matter). It is all pretty apparent once you take the top cover of the vent off (4 screws, 2 each side). The cable that runs from the control pad to the unit below uses a S-Video type connector and is keyed, so you can't get it back on incorrectly. Total cost in parts will be very minimal
For you DIY, remember there is AC voltage levels running thru this switch. Make sure YOU TURN POWER OFF when working on it and know what you are doing. You can get shocked.
Feb 24, 2008 | Viking VIPR101 Kitchen Hood
Viking VIPR101 Kitchen Hood Logo
623 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
