Question about Janome 4623 Mechanical Sewing Machine
My janome is stuck on reverse
I have a limited edition mechanical seewing machine that is stuck in reverse.when I bought the machine used th e reverse button seemed locked. when I pushed it it swemed to unlock and began sewing in reverse.Now the reverse button is loose and feels like it has come loose or off from the machine.everything runs perfect just in reverse can you help me?
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
mallow1
  • 35 Answers
SOURCE: Accessories for the Janome Mini Sew
Almost all of the Janome feet are interchangeable. Only a very few of their higher end electronic machines have special feet. So, if you ask for Janome feet, in general the stores give you the general purpose feet that work on most mechanical Janomes, such as Jem Gold, Decor, etc. Hope this helps!
Posted on Aug 16, 2008
mallow1
  • 35 Answers
SOURCE: looking for a instruction book for janome limited edition sewing machine my style 30
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
  • 46 Answers
SOURCE: Backward sewing machine
that sounds like the button is stuck. You may need to get it looked at.
Posted on Oct 24, 2008
  • 4 Answers
SOURCE: sewing machine only sewing backwards
your mech. need to be service
Posted on Apr 28, 2009
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
Janome 644D hand wheel stuck machine has never been used
See if you can free it by gently pushing the wheel back and forth ...is this a second hand machine bought as seen ? I am also wondering if a thread might be caught inside and making things stick ...
Mar 16, 2013 | Janome MyLock 634D Mechanical Sewing...
I have a janome 344 Limited Edition sewing machine. A repair company wants 88$ to fix the timing. Is this something I could easily do myself (I am only moderately mechanical savy) or should I let the pro...
the repair company has the correct tools to time the machine, I know $88.00 is a lot of money, but they have the experience to do the job. if you let the pro time the machine, make sure you sew on the machine immediately when you get it home, so you know the machine works correctly, & that your satisified with the stitches the machine makes.
Nov 03, 2011 | Janome L-344 Mechanical Sewing Machine
Hi, When I bought my overlocker 644D it came with a video which I found very useful as my reading is limited. The video tape has broken and I would like to purchase one as I found it so handy. Do you know...
The easiest way would be to go to www.janome.com, click products, sergers, then mylock634D (644D is also mentioned). Along the top, chose 'photos/video'.
If you would prefer to have the cassette, simply contact Janome Customer Service and they will send you a replacement ($$)
Jul 24, 2011 | Janome MyLock 634D Mechanical Sewing...
Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Lost manual
I couldn't find my manual for the Dual Sew 3500, either, and long story short, I discovered the manufacturer of Dual Sew is the parent company of Janome; that the Janome 4618 Limited Edition is virtually the same machine; wrote to Janome and they emailed me the PDF manual for th 4618LE. What a relief.
Apr 20, 2008 | Dual Sew 3500 Mechanical Sewing Machine
Janome 4623 Mechanical Sewing Machine Logo
248 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
