Toshiba satellite 1405
Cdr101 not ready reading drive q
Reset Satellite 1800-S207 to factory settings
its in the manual, lost it?
if yes, go to their web page, and read it there.
Toshiba , dot , com.
always there, and ready.
Oct 01, 2013 | System Integration Business Brand 160GB...
How do i factory restore toshiba 1405-s151? Is there a restore partition?
Yes, there is one. The hard drive is split into two patitions. Have a look.
If it is still intact then F8 will guide you there.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite 1405-S151 Notebook
My question (and neither LEXAR nor Panasonic nor Toshiba nor Curry's - a major UK dealer - seem able to answer this simple question): is there any reason why the Toshiba Satellite 1405 S151 should not be...
Yes - the SDHC memory card is a different format than the regular SD card. If you're trying to read the card on the laptop, chances are the reader slot is not capable of doing so even though it fits. You'll need an adapter that reads the SDHC to USB and connect it to the laptop.
Jan 19, 2011 | Toshiba Satellite 1405-S151 Notebook
Am not able to get drivers for Thoshiba satellite 1405-S151 laptop
Here is the website for driver support for your model of Toshiba Satellite:
Hope this helps.
Oct 19, 2010 | Toshiba Satellite 1405-S151 Notebook
How can i connect my toshiba satellite 1405-s151to my wireless ho
switch on the wireless either by a switch on the thing it's self or by holding down the FN key (bottom left of keyboard) then pressing one of the F keys i.e F1,F2 OR F8 (top of keyboard) The one with the little wireless symbol on it.
Then right click on the little PC screen icon in the tray next to clock at the bottom right of your screen & select "view available wireless networks" select your WI-FI from the list then click the "CONNECT"button.
put in your (SSID) & (WEP or NETWORK KEY) when asked, witch you'll find on the back of your router, then tick the box to hide the key if it's not all ready hidden, tick the save & auto connect boxes then your done.
GOD LUCK if you get stuck let me know.
Jan 16, 2010 | Toshiba Satellite 1405-S151 Notebook
Question about the toshiba satellite 1405 s151
This is an older model and should have a celeron chip in it.
I dont think you can update the processor.
Check the manual
Aug 30, 2009 | Toshiba Satellite 1405-S151 Notebook
I want to upgrade the hard drive in my satellite 1405-s151. how big of a drive will it handle?
As big as your willing to spend. I would suggest a 320 or better. You will not have to worry about running out of space then. Just make sure you get the correct type of hard for your system.
Thanks, Frank
Jun 14, 2009 | Toshiba Satellite 1405-S151 Notebook
To download Toshiba Satellite 1400/1405 manual, please click the link below:
Thank You
Nov 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Hard drive removal? Satellite 1405-S151
How to Add or replace your Hard Drive
1. Turn off the notebook, remove the power cord & battery
2. Use a screwdriver to remove the two screws that hold the hard drive compartment panel in place. (on the bottom of your laptop)
3. Gently lift the panel and slide it out.
4. You'll discover that the hard drive is bolted to the panel with four screws. Use the screwdriver to remove the screws. Separate the hard drive from the panel.
5. Slip the new hard drive into the panel and align the screw holes. Replace the screws.
6. Put the panel back into place and make sure it locks
in securely.
7. Replace the two screws that hold the compartment panel in place.
Oct 10, 2008 | Toshiba Satellite 1405-S151 Notebook
hit retry and follow the instructions
Jun 13, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
