Question about Protron PD-800 DVD Player
The picture is in blue
We can not get the picture to be in color. It is a blue & white. How do we get the picture to be normal?
  • 3 more comments
  • Anonymous Nov 02, 2007
    picture is blue
  • cazmac Dec 05, 2007
    I have the same problem - have tried messing with cables to no avail......Any other advice?
  • Anonymous Dec 22, 2007
    tv plays fine, tivo plays fine, DVD player has 2 colors green and blue. what can I do, if anything?
  • sfb1964 Jan 04, 2008
    My picture swaps in and out from normal color to greens and blues. A movie will start playing normally, then fade to greens and blues. Sometimes it will revert back to normal on it's own, or if I power off the player and restart it fixes the problem.
    Any ideas please? I am using a RGB cable.
  • nathan75 Feb 09, 2008
    when i play a video or dvd the colour flashes between normal and red and blue and black and white ive tried using the RF out cable and it does the same thing
I have a Mitsubusi DVD progressive scan DD6040. It worked great on another TV. I had to switch it. Now on the switched TV,I get sound, but only a black and white picture.
Does anyone know where I can download the instruction manual; I seemed to have misplaced mine.
Len
Posted on Jun 08, 2008
  • 513 Answers
Are you using an RGB cable?(red green blue) Try playing with both ends of the cable, or replacing it. If it still doesn't work you might have a problem with the RGB output on the player, try using S-video or analog video. Try using the DVD on another TV, just to make sure. Good luck, let us know what happened.
Posted on Jun 13, 2006
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
RCA mm32110 picture turn to blue and white like you have blue sunglasses on.
I'm not familiar with this set but it sounds like your blue crt has shorted out and is putting out so much color that it overwhelms the other colors. Is the picture also washed out? If so then your blue crt is bad. Probably not worth fixing. Let me know more about what the picture looks like.
hardrocko
Jan 31, 2010 | RCA Televison & Video
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Protron PD-800 DVD Player Logo
176 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
