Question about NetGear RangeMax NEXT WNR834B Wireless Router
Cannot get my Netgear WNR834B router to see the 'net
I've been using a Netgear WGR614 wireless router on my Windows XP home network for the last 2-3 years without issue, recently decided to upgrade to a wireless-N router, the Netgear WNR834B. Got a refurb'd unit ($25, couldn't resist), looked brand new.
I can access the router's setup mode easily, but I cannot access the internet in any browser whether using the router wirelessly or via a direct Ethernet connection between the router and my desktop. Windows can see the wireless connection, and signal strength looks excellent. Tried cycling the power on the router and cable modem a few times, no change. At a friends recommendation, I updated the router's firmware to DD-WRT---no difference.
This just feels like some inane Windows XP network configuration issue to me, but I can't figure out what I should be checking next. Thanks in advance for any suggestions.
  • 3 more comments
  • Anonymous Oct 28, 2008
    I have an identical problem, i filled in all the details and i think they are correct but the light on the Router says that it doesn't have an IP address yet.
  • kgivens Nov 12, 2008
    Solved my own problem, and the answer was embarrassing, but perhaps someone else will learn from this.
    I went through many reboot cycles in trying to get the router to handshake correctly with the cable modem (a Motorola SBV5220). I repeatedly rebooted both the router and the modem...or so I thought. My mistake was thinking that simply unplugging the cable modem for a minute or two would trigger a reboot, as it does with the router. In fact, it does not---this modem has a built-in UPS which kicks in instantly when you unplug it. Instead, you have to force a hard reset by depressing the tiny recessed button on the back of the cable modem with a paper clip or pin. Once I did that, the modem correctly assigned the appropriate addresses to the router, and the internet came to life. Precious hours of my life were lost in uncovering this stupidly simple fix. I hope someone learns from my bone-headedness.
  • kgivens Nov 15, 2008
    tekiMum, yes---I have IP addresses for both LAN and WAN showing.
  • Jannette Amandy May 11, 2010
    If you look at the status page your router, is there any Internet IP address?
  • Carl Navarro
    Carl Navarro May 11, 2010
    kgivens if you saved your old router, log into it and read the basic and wireless settings. Pay close attention to how the WAN is set up. If you happen to have PPPoE, it's the trickiest to set up, as it needs a username and password supplied from your ISP (usually with a DSL from the telco).
    Once you have those setting, forget the wizard, just configure it manually and let it test.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on May 02, 2009
I NEED THE DRIVER FOR ROUTER. NETGEAR WNR834B THANKS
Go to Netgear Support Home Page.
If you need more help post back!
Thumbs and testimonial are welcome!
Apr 28, 2011 | NetGear WNR834B RangeMax NEXT Wireless-N...
How do I set up my router
a router is the second peice in the loop of home networking. so you first need to come with an ethernet cable from the modem to the router, the port closest to the antenne. after this you can plug in to from the router to your computer, any port is fine. now you can use the router by it own software. type in to your browser (say IE explorer) the numbers 192.168.1.1
User Name = admin and Password = password, unless you changed it
and continue on to change and put in the wireless WEP codes and such.
a video tutorial is http://www.youtube.com/watch?v=l0xGvXWUAfI
You definatly want to encrypt your network as you dont want people on your net slowing you down.
http://www.netgear.com/products/home/wirelessrouters/simplesharing/WGR614.aspx
and to upgrade the firmware and follow manual instructions for version http://kb.netgear.com/app/answers/detail/a_id/2723/kw/WGR614%20manual
Mar 13, 2011 | NetGear WGR614 Wireless Router
My netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
May 18, 2009 | NetGear WGR614 Wireless Router
Win xp network
Check the wireless switch of your laptop if "on" or not. Then try again to scan available wireless network
May 11, 2009 | NetGear WGR614 Router
Trouble getting my router to go to wireless
A few things to look at:
1) On the front of the router, is the wireless LED lit up?
2) If it is not then it is either disabled or dead. Connect the router to your pc by cable and in a browser window enter 192.168.1.1.
3) At the login screen enter admin for the user and password for the password.
4) Once you are logged in, use the wizard to setup your wireless connection.
Good luck and thanks for using FixYa
Mar 26, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
1,515 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
