Hard drive will not power up. Has an internal 12v short circuit
    Problem Solver:
  • 10 Answers
How did you end up short circuiting it with 12 volts? Power supply only provides 5 volts. Surprising to me.
You better be looking for a new drive already!
Posted on Oct 18, 2008
Trouble shoot a sasmsung series3 notebook that had a short in the power port. Need possible area to check no power when switch is press to on.
Sounds like the power supply circuitry has failed...... mains is stepped down to 12V for the battery... but the circuit includes Choke (inductor) and smoothing capacitors. I suggest you remove the hard disk and mount it in a caddy... so you can recover your data using the hard disk as an external drive.
Nov 23, 2014 | Samsung Series 3 300E - 15.6" - Core i3...
HOW MANY AMP NEED A POWER SUPLY FOR A VERBATIM SNS2TB ?
Hi Jorge
Internally a standard 3.5" Hard Drive uses two voltages
about .7A on the 5v Line
and .55A on the 12v line.
So an External AC Plug Pack supplying 12v @ 1.5 to 2Amp should be adequate.
Be careful to match the polarity as marked on the back of your drive and use the correct thickness of the centre pin. There are 2-3 different sizes of this connector available at electronics component suppliers in case you make your own supply up.
Good Luck
Trevor
Sep 08, 2014 | Verbatim SNS2TB Store n Save 2 Terabyte...
I lost my power adapter for my simple tech 1tb 96300-41001-172, what is the voltage, amp rating as well as what pole is the +?thanks.
Open it up and look inside. Some enclosures use screws others use plastic clips which may require a tool thinner than a credit card to release the clips.
The Internal Drive...Is it a 2.5" drive that runs on 5 volt or a 3.5" drive that uses combined 12 volt & 5 Volt power supply.
These drives don't use much current. 1 to 2 Amp
The adapter may have had a single voltage output for 2.5" drives or a dual voltage supply for the 3.5" Probably 12v or 5v
Anyhow, there are lots of hard drive empty enclosures that can be bought... as hard drives internally use a standard connection for data & power. Just swap the internal HD over to a new enclosure.
Hope this Helps
Trevor
Aug 07, 2014 | SimpleTech Computers & Internet
Won't power up
Check for 12v constant and 12v remote. and be sure that u have a proper ground.
Check your speaker wiring for shorts (+ & - wires touching)
check that for shorts between your 12v constant and Ground at amplifier.
If these are fine it may be an internal problem.
Sep 25, 2013 | AudioBahn A6004V Car Audio Amplifier
What does code P0411, P2440 mean
P0411 Secondary AIR System Incorrect Airflow Detected
Possible Causes Setting Conditions
  • AIR pump pressure sensor reference (5v) circuit is open or shorted to ground
  • AIR pump ground circuit is open
  • AIR pump solenoid supply (12v) circuit is open or shorted to ground
  • AIR pump solenoid ground circuit is open
  • AIR pump relay coil control circuit is open
  • AIR pump relay coil power (12v) circuit is open or shorted to ground
  • AIR pump relay switch supply circuit is open or shorted to ground
  • ECM has failed
P2440 Secondary AIR System Switching Valve A' Stuck Open - With Automatic Transmission
  • AIR pump connector is damaged (check pins for damage, and for moisture)
  • AIR pump relay coil control circuit is shorted to ground
  • AIR pump solenoid power (12v) circuit is shorted to voltage
  • ECM has failed
  • both codes refer to emission & should be covered under factory warranty
  • good luck
Read more: Why am I having problems P0411 & P2440 w/ my 2006 Saturn Ion - JustAnswer http://www.justanswer.com/saturn/343l7-having-problems-p0411-p2440-w-2006-saturn-ion.html#ixzz1PyLeE07e
Jun 22, 2011 | 2009 GMC Envoy
Iomega external hard drive power is not coming on.
Samething happen to my Iomega screenplay media drive.
My problem was a AC/DC power adaptor that was in short-circuit.I bought one off EBAY and all good again.
Search for 12v dc 2.0 amp power adaptor.Has to be 2.0 amp ,as anything less ,will not work and most available are only 300 ma.
Good luck
Feb 19, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have simpletech 1.0TB external hard drive 96300-41001-135 that i bought from the US. I am trying to find a DC plug for it but i dont know which one i should get that don't damage my hard drive. ...
http://www.zlectronic.com/product/3727.html
Item Condition : 100% Brand New
DC Output ( V /A ) :12V 2A
Output Power(W) :24W
AC Input : 100 AC - 240 AC (50/60HZ)
Protection : Short and Overload Circuit Protection
Adapter Performance : High in Quality and Stability
Warranty Guarantee Period : 120 Days Warranty
Compatible Model :SIMPLETECH 96300-40001-001 Storage
Package Content :
- One Power Adapter
- One AC Power Cord fit your country
Nov 27, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
Lacie D2 Hard Drive Power Loss (2)
Yep, its shorted out, just buy a new power unit.
Aug 02, 2009 | LaCie (300740) 160 GB Hard Drive
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Computers & Internet Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
