Question about Pioneer PRS-D5000SPL Car Audio Amplifier
PRS-D5000 SPL UPON POWERING UP, POER LIGHT FLASHES CONTINUOUSLY. WHAT WOULD CAUSE THAT?
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
Does the Vivitar 120 Led Light Panel For Digital Camera And Camcorder - Viv-Vl-900 work on a NIkon D5000?
Yes. It won't give you all the features you would get with a dedicated flash unit, but it'll work fine to throw some light on the subject.
Feb 11, 2013 | Vivitar 120 Led Light Panel For Digital...
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
Upon powering up TV the green light comes on and within a second or two the red light comes on and intermitintly flashes, The tv never comes on?
The lamp or the ballast may be faulty. You'll need to replace the lamp first if this is a DLP. That's the cheapest solution. You can buy a lamp for your TV from discount-merchant.com.
Feb 04, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
Alarm light wont stop flashing
How old is your printer? Maybe a part in your printer has reached its service life and has to be replaced. Please indicate error messages if there are any.
Mar 31, 2008 | Canon i860 InkJet Photo Printer
Pioneer PRS-D5000SPL Car Audio Amplifier Logo
119 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
