Question about Engel Freezer 22 Qt. Fridge/Freezer
Servis frost free fridge freezer makin crackin noise afew tyms a day
I av a servis fridge freezer & it makes dis crackin noise about 2-3 tyms in a day espec after the cool air is turned on to cool the fridge freezer every so often.it doesnt make the noise everytym after the cool air is turned on tho onli sum of the tym.iv checked the back of the fridge freezer & it all looks ok.the temp in both the fridge & freezer is perfect.so i av no idea wats wrong wiv it.its always made dis noise since i had it 3yrs ago.the noise is mainly at nyt tym.i thought it may be the room temp goin down??
  • 1 more comment
  • spiderqueen5 Oct 19, 2008
    thank u sooo much for the advice sweetie.uv helped me alot & im relieved dat its nowt seriously wrong wiv it.thank u for helpin
    xxxxxxxxxx
    iv tried to rate he help advice i got but it wont let me.
    so i wanted to let u know dat ure advice was 100% helpful & i truly appreciate ur help :D
    xxxxxxxxxxxxxxxxxxxxxxxxxx
  • spiderqueen5 Oct 20, 2008
    ure sooo welcum.
    i jus wanted u to know dat ur advice was much appreciated :D
    it saved me alot of money on call out & costs for a repairman wen there was nowt to repair.so thank u soo much.
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
You are nice and i love the xxxxxxxxxxxxxxxxxxxxxxxxx's you sent
Posted on Oct 20, 2008
    President:
  • 1,462 Answers
This is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Posted on Oct 18, 2008
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
My Servis fridge/freezer sounds like Darth Vader
We had the same problem and discovered that the ice making device was "on" and we don't have it hooked up.  In the "on" position the pump begins to run but there is no water to pull so it sounds like breathing.  The ice making bar for us on our Jenn-Air is located near the ice trays and ours needs to be in the up position for off.  Hope this helps!
Jan 11, 2009 | Frost Freezer WCWO F15WA FREE - POCKET...
My fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Dec 14, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Engel Freezer 22 Qt. Fridge/Freezer Logo
529 people viewed this question
Top Engel Freezers Experts
John Tripp
John Tripp
Starnley Johnwells
Starnley Johnwells
Victor Nwachukwu
Victor Nwachukwu
Are you an Engel Freezer Expert? Answer questions, earn points and help others
