Question about RCA HD56W66 56" HDTV
Parts for RCA HD56W66
I am interest where to find some electronic components. CL031= .0087 uF 2000Vdc, CP150 Electrolitic cap., and Flyback transformer on the RCA deflection Board.
Thanks, David
HD56W66 powers on screen flashes foe a few sec.
On your Deflection board Look for Bad capacitors CP150 2200uf 16v CP114 CP120 in same circuit they will be puffed up on top if they are replace all 3 capacitors.other 2 are 220uf 35v and 330uf 35v
Mar 17, 2010 | RCA HD56W66 56" HDTV
I have a RCA d52w19. when I turn it on, the LED flashes 3 times and shuts off. Basically the same problem as everyone else. However, I changed CP150, CP120 and CP114 and still have the same problem. What...
if you replace the bad cap,s cp114 cp150,cp120 and still give you flashes 3 time you do have a bad flyback 21.40 for the flyback but in the same fix you see 3 fuse by the flyback hit them with solder thay is the power supply for the conv, borad.i work for quaker tv i seen a lot of that d52w19. you mite whant to look at the power wire that go to the front buttom con,t in front of tv if thay are pich in eny way the set will not come on. but you have a bad flyback.
Dec 07, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD56w66 turns on and off three times... replaced cap 114 120 and 150 turned on tv it turned on and off and then popped cap 120. What can i do?
Was cp120 installed with the correct polarity? Also was the microfarads the same as the original? Voltages can be higher but the Microfarad (uf) rating has to be exactly the same.
Oct 30, 2009 | RCA D52W19 52" Rear Projection Television
Exact Same Problem. TV turns on, sparks, then shuts off.
your most likely talking about clo31 which is a 0087 2000v box capacitor. You can get the replacement at the following link.
Jul 26, 2009 | RCA D52W23 52" HDTV CRT TV
RCA hd56w66
DO YOU STILL NEED HELP WITH YOUR TV IF SO ,I WILL TRY AND HELP! First ck capacitors cp150 cp114 cp120 2200uf 16v and 220uf 35v if 150 is puffed up on top replace all 3 capacitors also ck Ribbon connectors there is 2 of them thst conect deflection board to SSB board. resolder all pinns on FBT flyback transfomer.
May 28, 2009 | RCA HD56W66 56" HDTV
RCA ITC222 Board
Also replace CP150 and CP120 then check for an open 1.25 amp fuse. It looks like a little tiny brown box behind the composite inputs about an inch inward. We always change those caps regardless of the problem. GO GET EM TIGER. Let me know?
Apr 21, 2009 | RCA D61W20 61" Rear Projection Television
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
Rca d40 w20 lost component "spark gap"
Yes they are spark gaps and no when bad high voltage will arch out of them, Go to Cp150 2200uf 16 capacitor if it is puffed up on top it is bad .you have 3 that need re[lacing cp114 cp120 cp150
Jan 09, 2009 | RCA Scenium D40W20 40" Rear Projection...
Rca hd52w59 cp031 capacitor burnt
can't tell you the part number but found a site that sells these caps. Have the same problem and just purchased one.
Dec 13, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD56W66 56" HDTV Logo
453 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
