Question about LG WM2277H Front Load Washer
Water leaking out the bottom of door
When I do a load of laundry, I notice water leaking out the bottom of the door. It does not happen all the time, but it does happen a lot. Has been happening for a long time now but can not seem to find the problem myself. The washer is only 2 years old.
  • bhines6 Dec 24, 2008
    I have the same washer and it is two yrs old also and leaks out the bottom of the front door during the wash...has the door seal gone bad?
You are using too much detergent. Make certain you use HE (high efficiency) detergent, and one of the service technicians suggests only using about one tablespoon of detergent per load.
Posted on Nov 08, 2008
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
Water seems to be leaking from the bottom of my Maytag washing machine. Machine set for a large load. Water stopped, I added the detergent and then the soiled laundry. I went to get other laundry I had...
unplug washer. pull washer to you, have someone tilt the washer back and get a flash light and look for water spots on water pump,your drain hose,could be aclanp or just a hose we hope.
Sep 17, 2011 | Washing Machines
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine leaking water from underneath
It is possible it is just a loose hose or it could mean your trmp or the tub itself is leaking. I would try going to the back of the machine and take off the bottom panel.and take off the back panel. After removal start it and observe where the leak is happening.
Jun 14, 2017 | Estate ETW4100SQ Top Load Washer
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
LG WM2277H Front Load Washer Logo
221 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
