My cable connector (the thing that I screw my cable sord onto) broke off and I need to fix it
  • 84 Answers
You have to open the tunner up and solder it back only conect the pin to the place it broke from and becareful of your solder and solder mounting to for ground in the same position
Posted on Oct 18, 2008
My throttle cable broke at the carb how fix with out buying one
get one from an old bike ...
i would if you need just the end fixed use a choc box connector
used for connecting mains wires etc together
has two screws
strip off the plastic and you have a small bar with two screws
that can retain the cable inner
Apr 14, 2014 | Stihl Br 500 550 600 Backpack Blower...
99 Mercury cougar, the accelerator cable broke at the gas pedal how do i fix it? Do I need to replace the entire cable or just fix the part at the gas pedal?
replacing the cable would be the best thing to do it is hard to do on some models but depending on were it is broke and how much slack you have you could possibly get a cable connector for it like these
images?q=tbn:and9gcqfyo45jkcst_y-72ymudwhwtebag9vpseytoftptyd0-igfu2bkwspeaces
Sep 30, 2011 | 1999 Mercury Cougar
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Rear window falls down
The same thing just happened to me. I took off the door panel, pulled off the white barrier, and found the problem. There is a white plastic connector at the bottom of the window that connects the cable to the window and the track for the power-window. The connector has broke and the cable cannot grip the connector so the window falls. Its hard to tell because it will still be connected to the track, its just a small part of the connector that broke off. I have found that the only way to fix it is to replace the whole assembly. Don't waste time taking apart the motor housing, it is a pain. I found, and bought, the whole assembly on ebay motors for $120.00 shipping and all. If you have some tech abilities it shouldnt be too bad. If you need more info, just e-mail me, Im waiting for my part and will be assembling soon.
Aug 02, 2008 | 2002 Jeep Liberty
Dell dimension monitor output broke away from motherboard and now i get no output to monitor to "wake it up", nevermind being able to see anything on it. As soon as i unplug the monitor cable from the pin...
Depending on how much it has broke away, you may be able to resolder it back on, or find someone who can. Other than that it will be a new board, I suspect.
It seems at least a few connections are OK, so probably worth a try, before scrapping it.
Jan 16, 2008 | Dell (W2562) Motherboard
Do I have to tear out my wall?
If I understand you right the metal connector is on the wall connector and the wire is off of it if this is the case take some pliers and take the connector off the wall then take the connector and put it back on the wire just slip it in and squeeze the bottom of the metal connector so it tight on the wire this should help..
Nov 22, 2007 | Monster Cable (109611)
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
