Question about Dryers
Maytag Performa Electric Dryer, model # PYE2200AYW.
It works fine, but the air temperature is cold and will not dry the clothes.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Posted on Oct 18, 2008
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
My maytag gas dryer has always taken a very long time to dry clothes....usually 2 hours. I have had it for 8 years and it has been this way the whole time. is this normal?
i would check air flow out of vent normally with plugged vent extreame amount of moisture is present in dryer on high temperature of air moving through dryer is
max about 140 degrees normally with room temperature arpund 70 the drying time is normally 60minutes or less
contributing factors to long dry time
pinched vent hose final rinse cold water
below 50 degrees remove vent screen inside dryer clean with hot water shine flashlight into vent opening verify not plugged if have candy or probe type
temperature gauge verify temperature
at vent exit
Dec 12, 2009 | Maytag PYE2300AY Electric Dryer
Machine works but does not dry cloth no hot air drum? maytag performa
Chek closely all the tube going from in to out of ur dryer clean all ur filter even the furnace oune! check ur wirring, if all faisl dry nothing in ur machingr for one cycle. they wil { i hpoe
Nov 19, 2009 | Maytag Performa PAV2200
I have a gas dryer. Dryer heats up but doesn't dry clothes completely all the time. Sometimes I have to run it 2 -3 times. What do i need to replace? Maytag Performa Model # PYG2000AWW REV. 10 Serial #...
I got cut short.. and disconnected...so if this is a repeat, please forgive me:
Dryers 101
1. Heat alone does not dry clothes
2. Air alone does not dry clothes.
3. Only dry, heated air passing over and through clothes will dry them...
I recommend the following:
Set the dryer for "Air Dry".
Go outside and check the dryer exhaust.
Confirm that the exhaust is spewing out lots of air.
If it is, then you have a need for a technician to inspect everything - in person.
If it is NOT, the you need to determine the clog - or reason that air is not moving through your dryer, clothes and exhaust system.
ONLY 2 possibilities exist:
1. Fan motor is frozen and needs replacement....or
2. Duct/exhaust is clogged with lint and will not allow air to pass through.
Please check for both, clean/clear/fix as needed.
Nov 04, 2009 | Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Dryer not getting enought airflow to outside dryer vent
Normally it is six feet and not more than two bends, if it has been doing this you have buildup in the ducts and need to clean the ducts. I would suggest you make a new hole to address the problem. Also if you have a plastic pipe sometimes they develope a flap those blocks or slows the air down you can’t see this unless it is in dry mode. Any blockage will slow the air down allowing particles to drop down and gradually plug the vent, if the bends are too tight it to will slow down air flow and cause the same thing I suggest you cut the length of the hole to stop this problem if you can, it is not hard to do and I can give you the instructions if you post here.
Sep 03, 2009 | Maytag Performa PAV2200
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Jun 27, 2008 | Dryers
Dryers Logo
248 people viewed this question
Top Dryers Experts
