Question about RCA P56950 56" Rear Projection Television
TV started popping then died
My TV started out by making a loud crackling sound from the speakers, then started going off and coming back on every 15 minutes or so. This went on for a day, then the next day, when you press the power button, it just makes a little humming sound, never powers up or gives a picture, then goes off. Before it quit working, the picture was perfect.
    President:
  • 3,130 Answers
Sounds like the sound amplifyer IC in the set went bad and it holding down or blew out the voltage regulator. If your a tech first thing I would do is find the sound output IC and disconnect the main b+ lead and see if the tv will come on. if it did I would replace the audio output IC. If it didnt i would have to troubleshoot the Power supply for the missing voltage. if your not a tech its not advised to try to do this repair as there are no user serviceable parts inside this set. Seek A Pro to assist in this repair as there is hi voltage in this set even when its unplugged. Good Luck
Posted on Jun 11, 2006
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a loud popping and crackling noise from the speakers; it occurs after the tv has been on for 20-30 mins, and won't stop. After I power it off it will still continue for about 5 mins. Do the...
You have a bad audio output IC in the main board, you have a couple options as long as you don't use the sound from the TV...one is order a new main but if it was me I would take the back off and follow the wires that go to the speakers and unhook that plug.
Nov 15, 2017 | Samsung HLS4676S Television
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
No sound what so ever
it died and the parts aren't available, same problem here, even took it to an authorized outlet, parts aren't available
Jan 29, 2007 | JBL PB12 Subwoofer
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
RCA P56950 56" Rear Projection Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
