Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC (4420C) power fuse replacement?
Does the Brother MFC 4420C have a replaceable power fuse?
Printer was pluggged into 220V European power via an adapter....loud popping and circuit breaker tripped.
If the there is a fuse, how is it accessed and what is the replacement spec.
Thank you,
  • 133 Answers
It will just too expensive for replacing the fuse,
just go buy another printer will be the best for you.
Posted on May 23, 2009
Brother MFC-J4610DW is there a fuse replace inside?
replace a new power supply of your printer..
Jan 26, 2014 | Brother MFC-7820N Printer
I'd like to transform a Brother MFC 8220 from USA to AUS power
Probably cheaper to buy an auto transformer from 240 to 110 volts.
Mar 24, 2017 | Brother Mfc-8220 Laser Multi-Function...
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
It says error 41 caLL BROTHERS.. wHAT IS WRONG?
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Jan 26, 2010 | Brother MFC 4420C All-In-One InkJet...
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
My printer will not print anything on paper. Brother MFC 4420C, Just brings the paper out blank. It has new cartiages.
if you filled the ink with some of the kits, the ink was not totally compatible with brother printer, and most likely dried inside. if that is not the case, do the cleaning from the brother menu screen for all ink cartridges. if you under warranty call brother. it might take a while to fix, since they may send a local tech to replace the head since that is mostlikely issue. if out of warranty, you best likey choice, curb it and get new one with extended warranty.
Brother MFC 4420C PLS OPEN COVER error message
gof **** yourself, where the hell do you show your suppoused solution !!! ???? !!!!
Feb 19, 2009 | Brother MFC 4420C All-In-One InkJet...
Brother mfc-210
very sorry. There is no fuse to replace.
The reason is a defective part within the main circuit board.
The board needs replacing. This spare part costs more than a new mfc!
In case you are lucky (which means that you are a european citizen), you can contact brother of your country and send the mfc in for repair (three years warranty).
Jan 28, 2008 | Brother MFC 210C All-In-One InkJet Printer
I have a Brother MFC-665CW. I need to scan pictures and send them to my email. When I press the 'send to email' button it finds my pc and says 'connecting to pc' then nothing happens.
HELP ME PLEASE! What am I doing wrong?
Jan 03, 2008 | Brother MFC 4420C All-In-One InkJet...
Brother MFC 7420 All-In-One Laser Printer Logo
693 people viewed this question
James Cagle
James Cagle
Jim Keysor
