Question about Whirlpool GEW9250 Electric Dryer
Not Heating OK,..it took a tumble when we moved it and now it's not heating. All power phases are there, wiring looks good, heating coil has continuity, so does the elements and fuse. Any other places I can check?
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
Tumble dyer isnt getting warm, stays cold, its 5 years old
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Dec 28, 2009 | Washing Machines
TUMBLE DRYER NOT HEATING UP
Dec 04, 2009 | Dryers
No heat in tumble dryer
Good Luck,
Hope this helps
Nov 29, 2009 | Hotpoint Dryers
Dryer tumbles but no heat
Good Luck,
Hope this helps
Nov 27, 2009 | Whirlpool Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
Dryer not heating...everything seems OK
Y'ou are zeroing in on your problem. Read the info below and hopefully you will have your answer:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Heating element
Thermal fuse
Wiring
Please accept this solution and ask for any clarification.
Thanks
Rylee
Mar 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Dryer
If the motor can run, check the fuses in the house's panel. Electric dryers run on two phases of the 220-240 volts outlet; the motor on one phase, the heating coil on both phases. One of the two fuses may be burned out.
REMOVE the fuses before touching any component inside the dryer's housing.
If the fuses are OK, check if the the switch resting on the motor itself, has not burned terminal or wires.
Check if the heating coil is opened (burned)
Nov 07, 2007 | Kenmore 63942 Dryer
Whirlpool GEW9250 Electric Dryer Logo
103 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
