Question about HP Office Equipment & Supplies
When I print copies of words that should be in black and white it is using ink from the color cartridge and the print is varying between black and red. As a result my color cartridge is being used up instead of the black and white.
  • jimmyjak Oct 20, 2008
    Copies that should be in black and white are coming out in black, red,and pink. It is using my color cartridge instead of the black one and is depleting the ink in the color cartridge and not using the black one.Why isn't it using the black cartridge?
  • 77 Answers
Your cartridges could be in the wrong spot or the printer might not be recognizing the black cartridge so it is using the color one as a substitute.
Posted on Oct 20, 2008
    Master:
  • 538 Answers
Ok..open your printer preferences, and go to color management, and set it for greyscale only, medium or normal, whichever it prefers. And, when you want color, then you will need to go in a set it that way each time.
Posted on Oct 18, 2008
    President:
  • 1,952 Answers
CAN U TELL THE BRAND AND MODEL NO?
I had been out of color ink for a few months, so just printed using black&white mode. I installed a new color cartridge, and the computer is not acknowledging that a new cartridge is in. It will only...
Start, control panel, printers, your printer, printer preferences, advanced. Uncheck the complete-a-print boxes and also check to make sure the print in black & white box in unchecked.
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Apr 28, 2009 | Kodak ESP 5 Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
32 people viewed this question
Seeker5211
Seeker5211
