Question about Mico DVDR310 DVD Recorder
Mico espejo R311- no signal message
I have an old R311 dvd recorder which is acting funny. when trying to record from dv camera via the front sockets i keep getting the message "no signal".....
does anyone have the answer to my problem?????
3 Suggested Answers
SOURCE: DVD Set up
If it's the Espejo 311i model (mine was £30 from Morgan) I don't think you'll have any joy trying to select channels direct from the unit. Mine works fine with a Freeview box but channel selection is strictly on the latter, then the SCART goes into the recorder's No. 2 socket (No. 1 goes on to the TV). You can record whatever the box is receiving by selecting 'EXT2' as the source. Even if you never record analogue it's a good idea to plug an aerial feed into the Mico so it can set its clock. Note PDC doesn't work (for me anyway) when recording via the SCART. If someone has set it up strangely you can reset from scratch by unplugging, holding the front panel On switch in, then reconnecting to the mains while keeping the button pressed until the first setup screen appears on your TV. It will auto-tune to any analogue signals it finds on the aerial input. I could probably scan at least some of the manual if you are really stuck.
Posted on May 13, 2007
SOURCE: need instruction manual 4 Mico espejo r311 dvd ??download
Dear yesitsmary. Just read your post and have a hard copy + remote if still of use. BobsaGoodun
Posted on Aug 13, 2010
Not receiving a TV signal through the DVD recorder and cannot record programs or watch TV through the DVD recorder
Firstly you must have a good connection from your antennae to the dvd recorder, secondly a good connection between recorder and tv
via scart lead or hdmi. Check these out before you do anything else.
Mar 21, 2014 | Panasonic Dmr-XW380 Dvd Recorder
Need a manual for mico espejo r311 dv recorder
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 01, 2011 | Televison & Video
Need instruction manual 4 Mico espejo r311 dvd ??download
Feb 03, 2010 | Televison & Video
I get an error message that says
It means that the DVD Recorder thinks that the DV or Digital 8 camcorder is not connected to the iLink / Firewire connector. Check you have everything connected properly or if you want to record a different way there may be a memory option that allows you to change the way the unit is expecting to receive a signal. The DV/D8 just means DV or Digital8 which are 2 standards in video recording with different types of tape. The specific interface here is an iLink interface specific to Sony to allow control of the recording interface remotely. It is also possible that your iLink or firewire connected device is not compatible with this Sony model....
Dec 14, 2009 | Sony (DDU1613) (ddu1613black) Internal DVD...
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
Blocked
This is a dealer lock, removed by unplugging it, plug it back in whist holding down the play, stop and open/close button on the front of the machine.
Jul 17, 2009 | Mico DVDR310 DVD Recorder
Sony Digital video Camera Recorder DCR-PC6E/PC9E
hello..
did you received my message?
Clarification Request by welcomejee, posted on Sep 01, 2008 please mention what dvd recorder you have or you want to transfer movie files on PC hard disk.
Sep 01, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
DVD Set up
May 10, 2007 | Mico DVDR310 DVD Recorder
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Mico DVDR310 DVD Recorder Logo
139 people viewed this question
Top Mico Televison & Video Experts
Are you a Mico Televison and Video Expert? Answer questions, earn points and help others
