Sony kt-46wt520 standby light flashes 10 time than pauses. The tv will not turn on
  • 84 Answers
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Posted on Oct 18, 2008
My sony TV, when I press the power button it sounds like it is going to turn on then the standby button blinks 10 times then stops for 30 secs and then blinks another 10 times. What is wrong?
Flashing of the standby LED light 10 times (KP-46WT520) is a "High Voltage Protection".
Affected parts are as follows :
• Q8014 or Q8013 have shorted replace along with R8051 on D Board.
• IC8005 is damaged (D Board).
You must know how to test transistors, resistors using the multimeter if you are going to DIY.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to seek for an assistance of a qualified TV Technician to isolate the above faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 24, 2011 | Sony KP-46WT520 46" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony kp-46wt520 standby light flashes 10 times. Does not power up.
hello Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
shaun
Dec 27, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Sep 17, 2009 | Sony KP-44PX3 44" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Stanby just flashing 5 times - din't turn ON
Most likely the CRT drive boards have a bad video output IC or the A board has a defective IC452
Apr 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Standby light flashes/ TV won't turn on
He is right. The lamp (bulb) only last so many hours. Than you have to remove back of tv, open the door, replace lamp,
Mar 12, 2009 | Sony KP-46WT520 46" Rear Projection...
Should i have this fixed or buy a new tv?
OK LOOK IN YOU STK RESOLD YOU IC STK AND BE FIX
Dec 29, 2008 | Sony KP-46WT520 46" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
Electro Med Services...
