Trying to take top cover off satellite m55 s139
I am trying to take off the top cover to get to the fan and there is one small plug not will not come out that is connected to the mother board. do you know how I can remove this plug without damaging it.
  • 417 Answers
Go to this will show you how.
Posted on Oct 18, 2008
How to book on useing my laptop
Toshiba's website (Support) should offer a downloadable manual
Jun 22, 2011 | Toshiba Satellite M55 / M55-s139 /...
Toshiba satellite m55-s139 problem no screen no beep
The most common power reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Feb 01, 2011 | Toshiba Satellite M55-S139 Notebook
Unable to plug any usb devices in to this laptop running Windows 7
go to manage devices and update driver, download registry cleaner reginout to fix registry keys for usb drive
Aug 27, 2010 | Toshiba Satellite M55-S139 Notebook
How do i store a satellite m55- s1001 to factory settings without disk
to restore to the factory settings press F10 or F11 on startup and then follow the screen prompts you will get two options for recovery destructive and non destructive select the one according to your need destructive will delete your data.
Mar 20, 2010 | Toshiba Satellite M55-S139 Notebook
Window keep reboot by itself
try entering safe mode
if you can boot in safe mode you can try system restore
if that does not work either, you will need to reinstall a fresh copy of windows
Nov 13, 2009 | Toshiba Satellite M55-S139 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite m55-s139
sure..use a toothpick, to open the small thin lever, that is on top of that connector(like opening a trap door in the floor) then gently insert the ribbon cable, then push the small lever back down. make sure that the cable is centered, and fully inserted..
Oct 19, 2008 | Computers & Internet
Low brightness to no brightness on the m55-s139 toshiba notebook ;what are the possibility fix?
The backlight has probably gone out in your screen. Replacing a LCD screen is fairly easy and can be done alot cheaper yourself rather than paying 3-400 bucks to hire someone to do it.
This ebay page contains the screen you need and instructions on removal and installation for your screen. It also contains the necessary information to make sure you are purchasing the correct screen.
May 11, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
