Question about Eddie Bauer Lightweight Travel System 01-750-AFD
Adjustable belt behind the seat is broken
I found this stroller at a local 2nd hand shop and i want to buy it but the belt behind the seat is completly broken,....how do i fix it? can i get a replacment for it?
  • toberry4u Oct 18, 2008
    Neo, do you have this stroller? Cuase I know that the reclining belt is internally. Do you think I can still fix it? I do not have the model number. I would like to call the 800 # first to see if it is replacable then I will go ahead and purchase it, other wise I wont..
  • toberry4u Oct 19, 2008
    I need the model number for this stroller..Does anyone have one? A local 2nd hand store has this stroller but the adjustable strap that reclines the seat is broken its completly gone. I would like to call the manufacter to check if that belt is replaceable or fixable befor I buy it. And there for I need the model number.. Thanks in advance!
    Scholar:
  • 70 Answers
Yes! You absolutely can get any replacement parts. First you need the model number. The model number is located on the frame of the stroller on the right side just above the rear wheel. On some models, the model number will be found on a sewn-in labels found on the back of the seat. Once you find that, call Customer Relations, they can help. The number is 1-800-544-1108.. Good Luck.
Posted on Oct 18, 2008
Replace broken quinny zapp hooks?
Hi
The clips on the standard Zapp fabric for it to be inserted into the chassis and attached correctly are not available as separate spare part items. It would be a case of replacing the seat fabric.
Feb 23, 2012 | Quinny ZAPP Stroller
Do i have to buy a new seat for my quinny buzz 3 or do i have to get a new cover to make it xl seat?
The Quinny Buzz 2007-2010 model requires two seat fabrics. One is thicker, more padded, for a newborn/smaller child and the other is a more canvas type fabric which allows more space for an older child (up to 15kg). You should have received both fabrics when you purchased the Buzz. If you need to buy a 2nd stage (also known as the XL) seat fabric you can do so via your local Quinny retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 40GBP for the seat fabric and if ordered direct there will also be 3.99GBP p&p charge. You slide out the thicker fabric from the sub seat (seat frame) and slide in the 2nd stage seat fabric.
Oct 17, 2011 | Quinny Buzz 3 Stroller
Can you buy the front seat bars
Have a look on ebay, or go back to shop you bought from and ask them to order spare parts. some other baby shops will do this for you even if you didn't buy your item from them - so worth a try if original is not possible.
Mar 17, 2010 | Jane Powertwin - Navy Jogger Stroller
Folding and unfolding stroller/ how to adjust stroller seat?
if you place your hands on either side of the stroller keeping your hands on the side of the handle at the same time pull uo and that rfolds and unfolds stroller
Sep 11, 2009 | Quinny Freestyle 3 XL Stroller
Peg Perego Duette steering mechanism not working.
6 screws and one bolt hold the steering wheel on. The screws are obvious but to get to the bolt you need to remove the cover, it is directly above the steering wheel adjustment button, just pop it off with a flat head screw driver. then you can easily open it up and see what broke, call customer service and get the replacement part. I assume your cable broke...mine did too. <!-- from fixya rte -->
Aug 31, 2009 | Peg Perego Duette MT Newport Twin Stroller
The white buttons to adjust the tilt of the seat..
Hi we've had the same problem- does anyoe have any tips
Aug 03, 2009 | Bugaboo Frog - Black Stroller
Eddie bauer stroller manufactered in 2002 need model #
personally i would go cut off the seatbelt off of another old stroller or swing or bouncer and sew it in myself lol I got my son the Urbini Reversi stroller and the Sonti car seat that goes with it and im sooooo happy with i can just pop the care seat on to the stroller and go with no hassle
Jun 22, 2017 | Eddie Bauer Lightweight Travel System...
Is this stroller compatible with other car seats such as Graco?
The manufacturer will not say that your Graco seat will fit in their stroller safely, however you could try your Graco in it and see if you feel safe that it will not fall out or be pulled out by your toddler.
Perego prefers to market their items to go with their car seats only, but we have found that the Graco seats fit nicely in most strollers. You should hook the stroller harness on to the lap belt routing path on your car seat to ensure safest travel in the stroller.
Good Luck! from Moms Just Know
Oct 02, 2008 | Peg Perego Tender XL- Black Sable Twin...
Jane Powertwin
This is exactly what my husband did to our powertwin just 6wks into using it he managed to twist it slightly back into position and it holds so we have just put up with it but my god was I pissed at him! I was told it could be repaired by replacing the seat unit by a local pram shop but this seemed expensive we have managed with it like this for a yr no problems hope this helps.
Jan 14, 2008 | Jane Powertwin Azulon Stroller
Need to recline seat
On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
Nov 01, 2007 | Eddie Bauer C01078EBL Light Weight...
Eddie Bauer Lightweight Travel System 01-750-AFD Logo
117 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
