Question about Ariston Technologies LBE12X Ariston
Fabric softener compartment problem.
For the last week or so now my washing machine fabric softener dispenser compartment fills up with water after the cycle has finished, so that I have to remover the whole dispenser compartment and empty it every time before I can add softener to do another wash. Very annoying...It's not clogged up with washing powder or softener as I keep it cleaned regularly. I have tried doing a max. hot wash without clothes and softener to flush the system out but still the same problem. Help! I have also noticed a bad smell like stale/stagnent water coming from the drum, so have done what was suggested using a 1/3 distilled vinegar. Any more help on the fabric softner problem??
  • 2 more comments
  • Anonymous Mar 15, 2014
    Brown gunk invading my washing machine. I have no idea what has caused it and would like to get it fixed asap please. Any input would be very appreciated.
    I have a Samsung washing machine, top loader, with no debri filter. The modle # is WA5451ANW/XAA 02. The washer is producing the brown gunk described by the previos postings. We have recently had a water softener installed in our basement.. with the first load being ran last night with the new water softener and covering my infants clothing in brown pliable gunky flakes. Im not sure if it is being caused by the water softener or if it is just coincidental. I have checked the drum for sludge up and down including the top ring.. I've cleaned out the detergent reservoir... I've ran the "Pure Cycle" (cleaning cylce) with vinegar 3 times now.. the only thing I havent really done is check the water lines for built up.. but when I watch the water go into the machine I do not see the flakes present. Could it be that the water softener is braking up build up in my water lines? Im not sure what to do anymore.. I would like to prevent an expensive service charge, please help!
  • Anonymous Mar 18, 2014
    not taking softner and filter filled with water after every wash with softner in it
  • Anonymous Mar 27, 2014
    Why washing maschine do not take fabric softener?
Squeee, It's been more than a year since you posted this so I guess you must know the answer. It sounds like a Visit from an engineer(?) I've got exactly the same problem with a Servis Easilogic 1500 and would appreciate knowing what you had to do to resolve the issue.
Posted on Jul 05, 2007
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Iwd71250uk fabric softener staying in dispenser.
Compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow the grid.
Cleaning the detergent dispenser drawer
Remove the dispenser by raising it and pulling it out (see figure below). Wash it under running water; this operation should be
repeated frequently.
25825864-ineink0kisfnom0atbkujjcx-3-10.jpg 25825864-ineink0kisfnom0atbkujjcx-3-3.jpg 25825864-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Aug 17, 2015 | Indesit Washing Machines
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
706 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
