Question about Panasonic NN-S762 Microwave Oven
Panasonic NE-8051 microwave
Unit operates and cooks, but takes twice as long to cook the same product as before. What is a good temperature test for this unit and what is its wattage?
  • 99 Answers
Probely needs new magnatron.
Posted on Oct 18, 2008
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Need to know how to roast a whole chicken
Cooking meat is not a good idea especially chicken, few microwaves have a higher enough temperature to properly cook it, you are using a 700 watt microwave, the core temperature is simply not high enough to properly cook the meat. I strongly recommend the regular oven for proper cooking and safety, plus it will taste better.
Mar 28, 2012 | Haier 0.7CF 700W Microwave 700 Watts...
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
Just purchased our Cuisinart Stainless Microwave, plugged it in, read the operational instructions and set the clock. As a test, we tried to heat water....does not work. Any suggestions?
Yes! Take it right back to the store for exchange, cause could be a bad magnetron "that heats food" and a couple parts that work together with the magnetron,or there may be issues with the keypad, none of these will be cheap to fix.
Jan 30, 2011 | Cuisinart CMW-100 Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Old Quasar (Panasonic) Microwave won't work
I believe you need to set the clock on that before it will take cook programing. So Push the clear pad then push clock, Maybe clock twice. Been a while sorry!! set the time and I think you have to puch clock again, for it ro start the clock or start. As long as you do not puch cook then any time pushing start should only start the clock. That should do the trick. Good Luck!
Oct 19, 2017 | Microwave Ovens
Panasonic Microwave oven - cooking operation stops afer 2 seconds
Sounds like a short in the microwave circuit. One or more of the following four components has failed -
Transformer
Magnetron
Diode
Capacitor
Repair is not for the amateur, unless you know how to take things apart, and put them back together EXACTLY as the were found.
Parts are available on the Net, and you can get the P/N's off the old components to identify suppliers of the new ones.
Don't try and measure resistance of the diode. It's impedance is far too high to get a good reading. They're cheap anyway. Always replace the capacitor, they're cheap too. No way to test the magnetron, and the transformer is not easy to test either.
Jan 16, 2009 | Panasonic NN-S952 Microwave Oven
Temperature control
By default, it should cook at high (full) power.
On most brands, you would press Cook, enter the time digits, then press Start. And it automatically cooks at high power.
If it is losing heating power, your magnetron is probably failing.
This one's pretty old, but if you really love it, it's worth it. Owners of old microwaves usually love them. They're pretty strong units.
I just recently repaired an old GE (then by Panasonic / Quasar) convection microwave for a customer in New York. He shipped the whole microwave (95 pounds) to me and of course paid for return!
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You should be able to find original or generic replacement parts at various places. If you want more help finding parts or testing etc, reply back here or contact me directly.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Microwave Ovens
Panasonic NN-S762 Microwave Oven Logo
141 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
