Question about Toshiba SD M1712 Internal DVD Drive
Cannot find device driver anywhere.......
I recently purhased the SD M1712 Dual Layer DVD drive and for some reason my OS, WINXP SP2 no longer sees the device. It appears to be installed but not recognised. I have searched everywhere for the device driver both in at home, work and all over the net to no avail. The only thing I have fi=ound is updating the firmware which I have done but still the device is not fully functioning. If anyone has a copy of the drivers please let me know, asap. regards
    Problem Solver:
  • 17 Answers
Re: Cannot find device driver anywhere.......
This link will fix your problem:,sh,30564,221,3,.html
Posted on Aug 26, 2007
0 characters
3 Points
Dvd layer 2 not accessible on dual layer disk
Ah, the Dual-Layer Problem. Well, first off, you bought an LG. Problem solved!!! ASUS, Pioneer, TSSCorp, Sony, ASUTek USA, or any other brand OTHER than LG is good for burning Dual-Layer DVD's. And for God's sake, LEARN how to use Nero Ultra Edition for your burning needs. It has a technology called "BUFFER." you should really read up on that bro.
Apr 02, 2014 | LG SecurDisc 20x External Double-Layer DVD...
Can I use dual layer dvd +r 8.5 gigabit for
Yes, you can back up your data or a disk image your whole hard drive.
Depending the amount of data you want to backup, you can use
CD 700 Mb of data
Single layer DVD 4.7 Gb of data
Dual layer DVD 8.5 Gb of data
Mar 08, 2010 | Gateway (5500652) (  5500652)...
How can i test the Dual layer function of the teac DV-w28E?
You will need to burn something to a Dual Layer DVD. They are more expensive, but do hold up to 9 GB
Aug 17, 2009 | Teac DV 28E Internal DVD Drive
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
Dvd drive icon missing
Check the same place you did for upper and lower filters and also remove the upper and lower .bak entries. Then restart the machine. If the problem is still there check the drive connections and check to make sure the drive is still good.
Oct 18, 2008 | Toshiba SD M1712 Internal DVD Drive
My internal dvd recorder
The movies that u are burning are being copied to your computer, even in a compressed format that will take up space. Are u loosing h/d space. Are u using a copy program that uses the h/d as a temperary storage?
Apr 26, 2008 | Toshiba SD M1712 Internal DVD Drive
yes you can use nero 7 or cyberlink power dvd this software allow you to watch dvd movies. window media player doesnt play dvd without this softwares..
Feb 12, 2008 | Sony 16X DVD+/-RW Dual Layer OEM Black...
Cd\dvdrom drive
go to control panel, system, hardware, device manager, locate the drive, right click update driver, if fails, try windows update, if that fails google search for make and model and include "driver download"
Nov 11, 2007 | Toshiba SD M1712 Internal DVD Drive
Toshiba SD M1712 Internal DVD Drive Logo
319 people viewed this question
Top Toshiba DVD/Blu-ray Drives Experts
Brian Sullivan
Brian Sullivan
isaac johny
isaac johny
Are you a Toshiba DVD/Blu-ray Drive Expert? Answer questions, earn points and help others
