Question about Miller MATIC 180 MIG w/cart/AND SPOOLMATE 100 SPOOLGUN 907312011
I have a miller 180 autoset that does not feed the wire
Purchased a new Miller Autoset 180 and upon setup ran into a problem. It will not feed the wire. Check all the usual stuff....found and repaired a loose connection in the switch....check all of the connections from the gun to the board and reseated all still no success can anyone help....any hints or d oI have a bad board?
  • Anonymous Dec 04, 2008
    I have the same problem. Bought a new Millermatic 180 autoset. will not feed. I called Miller. They told me to jump the eletrodes with a wire where the gun connects and nothing. They told me to open the otherside to check the connections. I didn't do it because of the warranty issue.
    I have checked a number of blogs and this seems to be a common problem. They should recall them.
  • 169 Answers
If your welder is less than 3 years old your local Miller authorized service center will repair it for FREE. They can also check the serial number of your welder over the phone to see if it is still in warranty. For goodness sake DON'T tell them you've been mucking around inside the welder or they won't be able to help you.
That said, if the welder spins the feed wheels without any wire between them it probably isn't the board. There is the switch in the gun, the board, and the motor and brake assembly all needed to feed the wire.
Posted on Nov 29, 2008
Miller spoolmatic 30A it feeds wire then it will just stop then it will start again in a few miniteswhat could i check thanks
Posted on May 05, 2009
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
Spoolmate 100 wont feed
Check for binding int he inner sleeve first, then increase tension as long as feed motor spins. If feed motor does not spin check wiring to make sure it is connected correctly.
Sep 18, 2012 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
I have a Miller Shopmaster power source attached to a Miller model 22A wire welder. The problem is when the heat is set above 150 the wire feed pulsates and will not maintain a constant wire feed. Do you...
Check to make sure wire feed brake is not set too tight and that all cables and gun are clean. Also check wire feed wheels are clean and in good shape
Apr 09, 2011 | Miller Welding Tools
Millermatic 180 wire don't feed lights won't come on fan keeps running
Machine will run only on 220V, check your braker nust be at lest 20Amp.
Dec 18, 2010 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
What is the correct gas for miller renegade 180 weder generator mig
Depends on the application and type of wire you are using. If you are using flux cored wire you want Co2. If you are using mig wire 75/25 blend (Argon/Co2) would be my choice. Your wire should also give you a recommendation of which type to use.
May 07, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Mig proplem
Check the feed wheels at the wire spool make shure they are installed properly tight them if needed >>change tip >>
liner may need replaced.>
Dec 25, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
How to UNDO autoset (channel setter)?
If I am not mistaking this is the same set as the panasonic PV-c2020. I attached an owners manual link here this should help you. Good Luck. http://service.us.panasonic.com/OPERMANPDF/PVC2020.pdf
Mar 16, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar TV/VCR - how to UNDO autoset?
I find that sometimes you have to turn the antenna a little to receive more channels. Do you have a good booster? I gained an extra twenty to thirty channels by installing a good booster to my antenna.
Sep 29, 2017 | Panasonic PV-M1349 Combo
Miller MATIC 180 MIG w/cart/AND SPOOLMATE 100 SPOOLGUN 907312011 Logo
1,076 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
