Back to:
Tags:
Bosch 24 in. SHU43 Built-in Dishwasher
Stuck on agent (by 3 users)
posted by faji on Jun 10, 2006
My Bosch SHU43C dishwasher is doing something but not its regular process & the front panel agent indicator lamp is on.
I tried to reboot the machine by de-energizing but with the same result.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 25, 2008
I have tried regular wash and quick wash with the same resulting problem. I start the wash and it acts normally for about 1 minute preparing the wash cycle the countdown light is normal - I can hear the water start to fill then it stops. Then - the light on the wash button starts flashing and I hear a ticking sound - At this time the countdown light is off - there is also a sound lower near the bottom of the washer. I can push all three buttons to empty the tank - the countdown light goes to zero and the ticking stops. The tank empties.
Comment by embailey, posted on May 22, 2008
It will begin it's cycle and run for a minute or two and then it just stops. Ihave tries pushing the two buttons at the same time to cancel and drain and sometimes it will work after the reset other times it does not.
Best Solution
posted on Jan 18, 2008
Helpful (85)
courtdate
Rank:Wiz Wiz
Rating: 85%, 575 votes
REPLACE TIMER
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Stuck on agent:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
I have recently installed a new PC board in the machine,...
My Bosch Dishwasher Model shu43c05uc won't drain. It...
I have a Bosch sensiix station iron and it no longer...
I believe we have a Bosch SHU model. Recently the arm on...
The cover of the soap dispenser does not open every time. ...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
