Question about Gateway Computers & Internet
My computer keeps saying that the d drive is full and i was trying to delete some programs and deleted a driver that i need to get on line i went in and found it and reinstalled it but it will not let me go on line i had to go in on safe mode with internet right now what do i do to fix it
  • 156 Answers
Uninstall the driver in safe mode reinstall it in normal mode.
It resolves the problem
Regards,
Sandeep
Posted on Oct 18, 2008
Uninstalling google drive
Google Drive is a cloud drive, so uninstalling a Google Drive app on your computer does nothing to the contents in the cloud.
You would need to sign into your google account on-line, go to your google drive and begin deleting files from there to get the fastest results.
Note, it takes awhile to synchronize the cloud to another device, so if you had actually deleted files using your drive app, it would take awhile for the cloud to update to your device's representation of it. Deleting the drive app may have short changed the sync process.
Oct 24, 2017 | Google Computers & Internet
Setup cannot find Enterprise.WW\EnterWW.cab. Browse to a valid installation source and then click OK. I am installing MS Office 07 and midway through the install this is coming up. Any answers to this...
Hi There,
When it asks for the "valid installation source", direct it to the installation CD drive where the MS Cd is. There's a good chance it will heal itself that way and move right on ahead.
Regards,
Marcus
Sep 24, 2010 | Microsoft Office Professional 2007 Full...
My pc became so slow
Some classic reasons a computer slows down. 1. It's possible that your computer may have so many background programs running that there is not enough main memory to run your main programs. All icons in your computer's system tray are background programs using memory.
To see and remove all running background programs:
a. Press the Ctrl + Alt + Delete keys at the same time.
b. Click any program or task except Explorer or Systray.
c. Then click End Task.
Repeat steps b and c to quit all programs except Explorer and Systray which are necessary components of Microsoft Windows.
You should now have a clean system, however you have just removed the programs from your computer's memory
, they will all return the next time you start Windows.
If you don't want certain background programs starting when you boot, use the Start/Search function to find the program and either configure it not to run at startup, remove it from Programs/Startup, or delete it from your system.
2. Your hard drive could be too full of data to function efficiently. There should be at least 300MB-500MBs of free space to allow for disk file chores. Note that this mostly applies to the C: drive or whatever drive your Window's cache is on.
If your C: drive is too full, delete unused programs on the C: drive to make space.
3. Your computer could have a fragmented hard drive. This results from programs being loaded and deleted. Run the Window's hard drive defragmenter (Defrag) once a month.
4. If you have 256 MB of memory or less, or you like to play games, you may not have enough system memory to run your software efficiently. You should probably upgrade to 512 MB or more of system memory.
5. You could have old or conflicting Windows device drivers. An example would be you might actually have two entirely different video drivers on your system and Windows could actually be alternately using both of them.
To prevent this problem, First boot the computer in Safe Mode by pressing and holding the F8 key during startup, after the DOS memory check has completed.
While in Safe Mode select Start/Settings/Control Panel/System/Devices. Click on all the devices and see if the various drivers have any yellow or red exclamation marks (which indicates a driver conflict) and also determine if there are any duplicate drivers that can be eliminated.
You may have to delete and reload a driver to correct these problems. Duplicate drivers can and should be deleted.
6. As each new Windows program is installed and uninstalled, it leaves behind parts of itself that can slow down or crash your computer. These are mostly .dlls and other shared files.
It's also very possible when uninstalling a program that needed Windows system files can be deleted. When your computer asks if you want to uninstall shared files it's usually safest to say no -- even if your uninstall program claims the files are not being used.
Old Windows drivers can be found by booting into Safe Mode, then opening Control Panel/System/Devices and ridding your system of old drivers.
Another option is to use various system cleaning software, like Norton Utilities, Windoctor etc.
Otherwise, the only real answer to this problem is to reload Windows into a new directory which eliminates all old junk and leftover files. This is something to do last, as you will also have to reload all your Windows settings, drivers, and programs.
7. Your computer could be full of adware, spyware, viruses, or trojans. These are all nasty programs that literally take over the functioning of your computer so they can run their programs. You definitely don't want any of this junk on your computer. To get rid of these parasite programs, and to prevent them from installing in the first place, you need and up-to-date firewall, anti-virus, and spyware removal programs.
These are three separate software programs that must be running at all times except for when you are not plugged into the Internet. It is very important that these programs continuously update themselves or they will become out-dated and will no longer be useful. These programs can be purchased together or from separate manufacturers
May 11, 2010 | Computers & Internet
My 500gb HD is 97% full (mostly rubbish) and stuff that I don't want. How do I go about deleting it's contents. I'm using an iMac. I'd be grateful for any help. Thanks , Russ
Deleting from a external hard drive is the same as a internal.double click on external drive letter open to make sure you know what your deleting select all if all(from edit drop down ) delete.you can also just right click on folders and select delete.When your done you should defragment the drive to speed up drive.Good Luck.
Sep 17, 2009 | Western Digital My Book Essential Edition...
Memory is Full
I think, you have tried an online firmware update. Please let it finish. Memory full does not always means the storage is full. At technical world, memory actually means the Ram. You must not keep open many programs. Please try closing them to get free memory.
Unnecessarily opened programs take the memory.
Apr 21, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Computer keeps trying to install WordPerfect Office 12
It may be in your programs that you need to uninstall WordPerfect Office 12. It just seems like something is partially installed and wants to complete.
Jan 10, 2009 | Corel WordPerfect Office 12 Standard...
Deleted Program on accident....help?
Hi Jacie316
Ok, OOPS!, The only way you're going to be able to access your word files again is to re-install MS Office. I suggest you leave it as it is, and reinstall MS-Office when you get home or try to get a copy of MS Office, because that is the only way to access your files. No need to format your laptop though. Just reinstall MS Office. and everything should be fine again. I f you just need MS Word, then when you reinstall MS-Office again, choose manual installation and untick all other installations except MS Word. In that way you do not need to reinstall the complete MS-Office but instead, just MS Word.
Hope I helped.
Sep 10, 2008 | HP Pavilion dv1000 Notebook
Driver downloads but printer not showing up at all on the PC
If you do not have a HP Computer then try the following Steps:
Unplug the USB Cable from the computer.
Go to Start> Settings/Control Panel> Add or Remove programs and delete all the programs you see for HP.
If you are not able to deleted them the go to Safe mode and delete them.
To go to safe mode restart the computer and while restarting the PC you should keep on pressing the F8 tab in your Keyboard.
And then go to My Computer>Local Disk:C> Then Program Files> and delete the entry for HP only (Not Hewlette Packard)
Then in Local disk:C go to Windows and open Temp Folder and Empty the temp folder, and in windows folder rename TWAIN_32 as OLDTWAIN_32.
Close all the windows and open recycle bin and empty Recycle Bin.
And then if you have the All-In-One CD the insert the CD and if you get a installation screen EXIT form that.
Go to My Computer and Right click on the CD which should say CDB-AmericasEuro-Express.exe and open the folder which says UTIL> and then you should see a file whic says UNISTALL_L4
Double click on the same and and follow the on screen instruction (There are 4 Unistall Process if it Prompts to restart then try restart later and complete the full uninstall process, if it does not let you to proceed withou restarting then restart and try the same UNISTALL_L4 once again.
And after it restarts reinsert the All-In-One CD and try a fresh new install.
And before trying these steps please go to Start Settings/Control panel>then printers and faxes and delete all the icons for any printers listed there.
Good Luck
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Soundmax
I don't know if you manually erase those drivers, but I recommend you reinstall the drivers with the setup option, then uninstall them, again reinstall them ans see if work, or depending the OS if is Xp or Vista, ?
Nov 06, 2007 | Audio Players & Recorders
I can't delete the songs and the computer says my mp3 is "full"
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Oct 19, 2007 | SanDisk Sansa m240 MP3 Player
Computers & Internet Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
