It looks like you're really handy with electronics. I read through your detailed explanation of how to fix this TV when it stops turning on, and I think I understood most of it.
I'm pretty bright and like fixing things although I don't have any experience with electronics. I'd like to fix my TV myself but I'm in college and don't have any power tools or soldering supplies.
Do you think it's worth buying these supplies and attempting to fix it myself? What supplies would I need?
Any advice you have would be greatly appreciated. Have a fantastic day! -Jackie
It's worth a shot.First I would open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.Then you can get the stuff you need to replace the bad capacitors.This should get it working again.If it is anything else,you will have to buy some equipment like a multimeter to test the components,and find which ones are bad.As far as what you need,it all depends on how much you want to get into this,and,or other electronics.You would need a soldering iron,solder,solder braid,and a desoldering bulb/plunger to get started.I hope this helps.If you have any questions,please let me know.Thank You very much!
Hi, I have an Akai LCT2785TA LCD tv approximately 2 years old. I was viewing the tv the night before...
(More)
Hi, I have an Akai LCT2785TA LCD tv approximately 2 years old. I was viewing the tv the night before it worked just fine, turned it on the next day and I get no picture. Everything works just as it did before but now when turned on the Akai logo screen flashes for a few moments then the screen is totally black. I still hear the audio. Could this be a blown bulb? Thanks for your help
Our Akai tv will not power on and stay on. In the past we were able to unplug the tv and replug it...
(More)
Our Akai tv will not power on and stay on. In the past we were able to unplug the tv and replug it and then the power would come on but now the power light will turn green then turn back red. Model LCT 2785TA
I try to scan for DTV channels and this tv doesn't find any. When I scan using DirecTV receiver then...
(More)
I try to scan for DTV channels and this tv doesn't find any. When I scan using DirecTV receiver then they are found. Why?
My LCT2785TA TV has only one channel now. I cannot change the channel with the controls on the TV...
(More)
My LCT2785TA TV has only one channel now. I cannot change the channel with the controls on the TV or with the remote. New remote did not help. All the controls on the TV work except the channel buttons. Any suggestions?
