Question about Dewalt 18 Volt Compact Drill Kit
Removing the chuck on a dewalt DC925 cordless drill.
I am trying to replace the chuck on my Dewalt DC925 cordless drill but I can not remove the old chuck. There is no screw and I tried tightening an allen wrench in the chuck and taping with a hammer. The chuck slips . I am replacing the chuck because it will not hold a bit in reverse. I have heard the chuck is glued to the shaft.
  • 1 more comment
  • Gary Brackett Oct 20, 2008
    I am trying to replace the chuck on my Dewalt DC925 cordless drill but I can not remove the old chuck. There is no screw and I tried tightening an allen wrench in the chuck and taping with a hammer. The chuck slips . I am replacing the chuck because one of the three grips is broken. I have heard the chuck is glued to the shaft.
  • menace000 Nov 11, 2008
    i am trying to remove the chuck it will not hold the bit in reverse and i dont think it is under warrenty i have no recipt.. how do you remove it ???? Brad...
  • menace000 Nov 17, 2008
    hey guys i have the same problem with the bit in reverse it wont hold i do not have a svrew holding the chuck ... is it threded ??? Brad...
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Posted on Nov 16, 2008
    Novelist:
  • 99 Answers
Some chucks are threadlocked but normally not with a massive amount. I assume you have the cutch set to the drill position and the gearbox set to the slower speed. If the clutch is set to drill and slipping I would suggest it needs attention. You may find the only way to remove the chuck in this situation is to dismantle the clutch and grip the output shaft from behind and unscrew the chuck. This may cause damage to the spindle so it depends on how much parts /repair cost you want to risk.
Posted on Oct 26, 2008
  • Monte 86 Oct 11, 2010
    I just replaced the chuck on my DC925. There is no screw holding this chuck in place it is just held by threads and loctite. The chuck would not hold the allen wrench so I just used a pin spanner wrench and gave it a rap with a hammer. The chuck spins right off..
Thanks Stug_57u but I already took it to a Dewalt repair center and they replaced the chuck free of charge because it was still under warranty which I did not realize at the time I was trying to remove it.
Posted on Nov 02, 2008
Wher do pin bearings go into the transmission of a dewalt 18v cordless drill
if its like my DC925,you have to remove front of trans. toward chuck! its a plastic piece with a s.s. flat spring washer. if washer falls out install from bottom of plastic when removed from trans. bearings stand in gear grooves. make sure if nut falls out match 1 with 1!
Oct 11, 2013 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt cordless releases bit when unscrewing under pressure
In the past when this has happened to me I have had to replace the chuck. Problem is, the chuck is not a normal one and the correct chuck has a list price of about 65 pound and needs a special service tool to take it off and put it on again.
Jun 15, 2012 | Dewalt DC925 Cordless Drill
How do i change the chuck on my dc925
under my handle for this site, go to the tip section and I have detailed instructions on how to remove this chuck. Let me know if you need more assistance.
Apr 19, 2011 | Dewalt DC925 Cordless Drill
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
DeWalt DC925XE Keyless chuck keeps undoing when reversing screws releasing driver bits.
You must never oil the chuck so if this has been done then it can be the cause of your problem
Sep 28, 2010 | Dewalt DC925 Cordless Drill
How to--- chuck removal DC925 drill DeWalt
Open the chuck fully. Inside the center bottom of the chuck you will normally find a reverse threaded lock screw that you must first remove. If it is hard to loosen, you may need to heat it with a micro torch or a heat gun to make the thread lock compound slip. Then fasten the smaller end of an allen key firmly into the jaws of the chuck. Engage the low gear. Then hit the longer end rapidly with a hammer to unscrew the chuck by rotating it anti clockwise.
Sep 05, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I want to switch the drill chuck.model dc 925.how to do it?
CONTACT YOUR NEAREST TOOLKING STORE THEY WILL ADVISE YOU
Aug 13, 2009 | Dewalt DC925 Cordless Drill
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
2,757 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
