Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi vs-45605 Hey can you help solve this? http://www.fixya.com/support/t1100531-mits_vs_45605_picture_jumping_see_video
  • 1,512 Answers
Hi
Posted to the link you gave. Good Luck. Thanks for the request :)
regards
robotek
Posted on Oct 18, 2008
It comes on and then it goes off
This just happened to me as well. Keep it plugged in for about five minutes without trying to turn it on. Then try. This will ultimately tell you that your convergence chip is out. If the screen comes back on, it will look distorted. This is most definantly that chip going out. I suggest a tv repair kit or trash it. You can find a vs 45605 here: http://www.tvrepairkits.com/xcart/vs-45605/
Jan 17, 2013 | Mitsubishi VS-45605 50" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-45605
Sure. I have had one repair person tell me it's not worth fixing. But, I am surprised that there have been no solutions posted.
James
Oct 08, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mits VS-45605 Picture Jumping - See video
Hi Jim and seirig
The PIP module(problematic with this model) can be removed and bypassed, there are guys on ebay selling kits to do this. You probably DO have capacitor problems in the vertical stages(as is the problem with the PIP module also). They do not always "bulge" as an indicator of failure. Often they just leak out. If the bulge occurs about a safety vent stamped into the top of them means they have overheated, and the stamped vent is meant to rupture to prevent them from exploding. If there is any white residue on the board or corrosion about any caps, this is casued by them venting on the bottom side instead, then they have failed. if they move about easily then their connecting legs, they may have corroded off up inside the can of the cap itself. Sometimes they can appear physically AOK, and be faulty. Checking them with a meter is really the only sure way of determining a caps worthiness. It is a common problem with any electronics these days. They just dont build them to last. Surface mount capcitors actually have a shelf life even in storage!! Replacing all the caps in a stage to resolve a problem like this is often gives the best result. One failing cap can put pressure on others, and the overheating issue may reoccur. Best to get quality brand parts to replace failed caps. These guys are everywhere in the world, and easy to navigate, just search for you part :)
A FixYa is a good reward for my time to extend this advice to you. If you have more questions, I am also happy to attempt to answer them for you. Cheers
regards
robotek
Oct 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
CS-27403
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Jan 27, 2008 | Mitsubishi VS-45605 50" Rear Projection...
HDTV 1080
IF your Mits model # is WS-xxx13 type, then the DM module
is at fault.....requires replacement of four 1000mf 25V 105
degree capacitors.........for more info......go to.......
www.chrisandnat.com/projects/blinkingtv/blink.htm .............T.
Dec 18, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
