Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Carpet setting not working, no brush turn, no light, etc.
I have the same problem thats been mentioned by others. I was vacuuming the rugs when the brush stopped moving. Suction is good, but no brush and no light. I've tried the reset to no avail. Any thoughts? Thanks!
  • Anonymous Feb 14, 2009
    I had same problem, how to fix it? please help
  • 125 Answers
If the motor is running, its the belt, if not there is a break in your wire likely in the stub going from the wand to the head
Posted on Dec 30, 2008
Shark navigator vacuum
IF it is belt driven brushes, replace the belt. If not then the motor is most likely bad.
Aug 25, 2013 | Vacuums
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Rug brush won't turn. I did get it stuck in a
sure...it must, come back to normal, try cleaning the dust pan of it, then reset it..!
thank u
Jul 16, 2009 | Vacuums
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Oreck XL21
What does the belt tension feel like? Is it possible that the new belt you fitted is a bit too long (and starts to slip as soon as it encounters any real resistance). Any more methodical diagnosis is going to depend on observing which bits of the machine are still moving, and which aren't when the brush roll is stuck. Gather this information with caution, as it's a good way to lose a couple of fingertips. A.
May 17, 2007 | Oreck XL21 Bagged Upright Vacuum
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
147 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
